Pinebook Pro not turn
(03-11-2022, 12:21 PM)wdt Wrote: You really need to get/buy a cheap DVM (digital volt meter) and measure battery
Then you will know what is happening.  Cheap ones are <$20 (and quite adequate)
On pg 24 Table3 (data sheet)....... Charge complete, Sleep mode, Charge disabled.....LED off
Sometimes pbp will work without battery, sometimes NOT
I don't know what the led does when bypass cables are connected
If the battery is too low, yes the power button will do nothing
Really, you need to measure battery V
Grazie molto per la risposta.
Comunque vi chiedo, è possibile che connettendo i cavi del bypass e collegando il barilotto il PBP non si accenda?
Thanks very much for the reply.
Anyway I ask you, is it possible that by connecting the bypass cables and connecting the barrel, the PBP does not turn on?
Pinebook Pro not turn - by carbo29 - 03-09-2022, 12:48 PM
RE: Pinebook Pro not turn - by josmo - 03-10-2022, 11:48 AM
RE: Pinebook Pro not turn - by tophneal - 03-10-2022, 01:04 PM
RE: Pinebook Pro not turn - by wdt - 03-10-2022, 11:19 PM
RE: Pinebook Pro not turn - by carbo29 - 03-11-2022, 12:47 AM
RE: Pinebook Pro not turn - by wdt - 03-11-2022, 02:05 AM
RE: Pinebook Pro not turn - by carbo29 - 03-11-2022, 02:20 AM
RE: Pinebook Pro not turn - by carbo29 - 03-11-2022, 05:18 AM
RE: Pinebook Pro not turn - by wdt - 03-11-2022, 12:21 PM
RE: Pinebook Pro not turn - by carbo29 - 03-11-2022, 01:06 PM
RE: Pinebook Pro not turn - by wdt - 03-11-2022, 10:41 PM
RE: Pinebook Pro not turn - by carbo29 - 03-12-2022, 12:42 PM
  looking to buy one pinebook pro (mainland China) duanduan 3 1,917 03-21-2024, 07:44 PM
Last Post: wangyukunshan
  Cellular module for Pinebook Pro Lotech 1 305 03-05-2024, 05:40 AM
  Screen on pinebook stays black but can ssh into machine tuxxpine 0 240 02-23-2024, 04:22 PM
Last Post: tuxxpine
  Sale my ANSI PineBook Pro cuthbertdavies 0 231 02-14-2024, 09:12 PM
Last Post: cuthbertdavies
  Compiling with -j6 on the Pinebook Pro (Overheat) KC9UDX 0 168 02-14-2024, 09:01 AM
  Pinebook Pro in EU for Sale - €90 jan_vdk 2 558 02-07-2024, 02:12 AM
Last Post: 23Ro
  Pinebook Pro for sale tomekdev 2 623 02-01-2024, 11:35 AM
Last Post: tomekdev
  Video Editing Is Possible On The PineBook Pro! ImmyChan 10 7,242 12-17-2023, 09:29 PM
Last Post: insideau786
  Brand new Pinebook Pro doesn't boot after Manjaro update johnboiles 8 2,001 12-15-2023, 02:11 PM
  Happy eMMC and SDcard OS usage for Pinebook Pro Newbies... Paulie420 42 59,168 11-20-2023, 06:22 PM
