Pinebook Pro not turn
A questo punto non credo sia un problema della batteria, non riesco proprio a capire.
Come posso capire che la scheda madre sia funzionante?
Quando metto il barilotto si accende la luce rossa della ricarica, se stacco batteria e unisco i due cavi all'intero e poi attacco il barilotto non si accende nessuna spia rossa. Ho paura che si sia sia guastata la scheda madre, ma potrebbe essersi anche guastata la tastiera visto che premendo il Tasto di accensione non succede nulla.
Non capisco come sia possibile che da un giorno all'altro sia successo questo.
Aspetto vostri consigli.
At this point I don't think it's a battery problem, I just can't understand.
How can I tell that the motherboard is working?
When I put the barrel on, the red recharge light turns on, if I disconnect the battery and connect the two cables to the whole and then I attach the barrel, no red light comes on. I am afraid that the motherboard has failed, but the keyboard could also have failed as nothing happens when pressing the Power button.
I don't understand how it is possible that this happened overnight.
I await your advice.
Pinebook Pro not turn - by carbo29 - 03-09-2022, 12:48 PM
RE: Pinebook Pro not turn - by josmo - 03-10-2022, 11:48 AM
RE: Pinebook Pro not turn - by tophneal - 03-10-2022, 01:04 PM
RE: Pinebook Pro not turn - by wdt - 03-10-2022, 11:19 PM
RE: Pinebook Pro not turn - by carbo29 - 03-11-2022, 12:47 AM
RE: Pinebook Pro not turn - by wdt - 03-11-2022, 02:05 AM
RE: Pinebook Pro not turn - by carbo29 - 03-11-2022, 02:20 AM
RE: Pinebook Pro not turn - by carbo29 - 03-11-2022, 05:18 AM
RE: Pinebook Pro not turn - by wdt - 03-11-2022, 12:21 PM
RE: Pinebook Pro not turn - by carbo29 - 03-11-2022, 01:06 PM
RE: Pinebook Pro not turn - by wdt - 03-11-2022, 10:41 PM
RE: Pinebook Pro not turn - by carbo29 - 03-12-2022, 12:42 PM
  Pinebook Pro Initial Impressions kunger 443 585,027 04-16-2024, 07:29 PM
  looking to buy one pinebook pro (mainland China) duanduan 3 2,241 03-21-2024, 07:44 PM
Last Post: wangyukunshan
  Cellular module for Pinebook Pro Lotech 1 378 03-05-2024, 05:40 AM
  Screen on pinebook stays black but can ssh into machine tuxxpine 0 282 02-23-2024, 04:22 PM
Last Post: tuxxpine
  Sale my ANSI PineBook Pro cuthbertdavies 0 275 02-14-2024, 09:12 PM
Last Post: cuthbertdavies
  Compiling with -j6 on the Pinebook Pro (Overheat) KC9UDX 0 208 02-14-2024, 09:01 AM
  Pinebook Pro in EU for Sale - €90 jan_vdk 2 639 02-07-2024, 02:12 AM
Last Post: 23Ro
  Pinebook Pro for sale tomekdev 2 711 02-01-2024, 11:35 AM
Last Post: tomekdev
  Video Editing Is Possible On The PineBook Pro! ImmyChan 10 7,485 12-17-2023, 09:29 PM
Last Post: insideau786
  Brand new Pinebook Pro doesn't boot after Manjaro update johnboiles 8 2,172 12-15-2023, 02:11 PM
