plasma-dialer doesn't call
(03-04-2022, 09:03 AM)acrux Wrote: If the preinstalled version was older than beta 9, then it was based on ofono. So if you upgraded it to the latest, then it was replaced with modemmanager.
There could be leftover ofono files, but they should not be in use.
I'd suggest to flash latest - beta11 to a SD card and do a fresh start. Or test any other OS. If you are satisfied, install it to a internal memory.
I tried the latest dev image Manjaro-ARM-plasma-mobile-dev-pinephone-20220304 and even with data on (otherwise turns off modem), I was unable to make calls or send text messages, I don't believe the telephony stack works properly with ModemManager yet. The modem was on and responded to AT commands via mmcli.
Make sure modem is on with:
mmcli -m any -e
check eg with
mmcli -m any --messaging-list-sms
mmcli -m any --command='AT+QCFG="ims"'
I downgraded to the stable branch and had the same problems.
I booted back to Mobian on SD card and everything works for me, though I think there are still some missed calls / SMS notifications when in suspend mode. This is with the latest Quectel firmware, I haven't tried with Biktorgj one.
I'm on a non-VoLTE MVNO.
Hopefully it gets fixed eventually, annoying the when the phone part doesn't work (reliably).
plasma-dialer doesn't call - by Ant - 03-03-2022, 10:37 PM
RE: plasma-dialer doesn't call - by acrux - 03-04-2022, 09:03 AM
RE: plasma-dialer doesn't call - by dcinoz - 03-05-2022, 05:37 AM
RE: plasma-dialer doesn't call - by israel - 03-10-2022, 10:55 AM
RE: plasma-dialer doesn't call - by Ant - 03-18-2022, 06:51 PM
RE: plasma-dialer doesn't call - by israel - 03-18-2022, 08:19 PM
RE: plasma-dialer doesn't call - by Ant - 03-18-2022, 09:07 PM
RE: plasma-dialer doesn't call - by israel - 04-08-2022, 03:09 PM
  PinePhone Doesn't Boot LED Doesn't Show Any Signs When Charging dorkydev 1 198 04-02-2024, 11:50 AM
  Problems updating KDE Plasma Mobile OS IMSAI8080 6 3,305 06-30-2023, 11:39 PM
Last Post: ionmich
  Cannot call at several mobile phones Gon 3 1,305 05-04-2023, 05:18 AM
Last Post: Gon
  Pine Phone Doesn't Recognize New MicroSD Card _radv_ 3 1,397 11-23-2022, 05:19 AM
Last Post: _radv_
  My Pine doesn't allow me to install to eMMC on different OS's Kimberley van Buyten 1 1,336 05-31-2022, 04:26 PM
Last Post: fxc
  WIFI doesn't stay connected Matt73 0 808 03-10-2022, 08:10 AM
Last Post: Matt73
  call immediately terminated jyoung 10 4,994 01-14-2022, 02:19 PM
Last Post: jyoung
  PinePhone Stuck in landscape (Manjaro Plasma) Ephraimlad 1 1,486 01-04-2022, 05:41 PM
Last Post: jasonriedy
  New phone - setup - only landscape - KDE plasma westsamoa 2 1,993 09-27-2021, 02:23 AM
Last Post: Uturn
Exclamation KDE Plasma - cannot answer calls or read received SMS Tenticle 1 2,532 07-12-2021, 03:21 AM
Last Post: TfromTexas
