DNS Problems with Mobile Data
#23
(02-20-2022, 12:12 PM)Zebulon Walton Wrote: You can manually set your name servers in /etc/resolv.conf. However if you directly edit the file it will be overwritten on next boot or network connect. Here's how to make it permanent, assuming Mobian is set up the same way as stock Debian and Ubuntu:
https://www.tecmint.com/set-permanent-dn...tu-debian/
Wonderful, works like a charm so far. Thanks for the information.
DNS Problems with Mobile Data - by arno_nuehm - 02-20-2022, 08:04 AM
RE: DNS Problems with Mobile Data - by jsch - 02-20-2022, 11:05 AM
RE: DNS Problems with Mobile Data - by henrythemouse - 04-16-2022, 06:29 PM
RE: DNS Problems with Mobile Data - by dukla2000 - 02-20-2022, 12:14 PM
RE: DNS Problems with Mobile Data - by arno_nuehm - 02-20-2022, 02:43 PM
RE: DNS Problems with Mobile Data - by user641 - 02-20-2022, 06:05 PM
RE: DNS Problems with Mobile Data - by dachalife - 02-21-2022, 11:54 AM
RE: DNS Problems with Mobile Data - by anonymous - 02-21-2022, 05:23 PM
RE: DNS Problems with Mobile Data - by arno_nuehm - 02-22-2022, 04:16 AM
RE: DNS Problems with Mobile Data - by anonymous - 02-22-2022, 06:04 AM
RE: DNS Problems with Mobile Data - by moxx - 02-22-2022, 08:01 AM
RE: DNS Problems with Mobile Data - by powo01 - 02-23-2022, 05:58 AM
RE: DNS Problems with Mobile Data - by arno_nuehm - 03-03-2022, 01:58 AM
RE: DNS Problems with Mobile Data - by Zdenek - 03-03-2022, 03:31 PM
RE: DNS Problems with Mobile Data - by user641 - 03-03-2022, 04:16 PM
RE: DNS Problems with Mobile Data - by arno_nuehm - 03-04-2022, 03:36 AM
RE: DNS Problems with Mobile Data - by user641 - 03-05-2022, 07:43 AM
RE: DNS Problems with Mobile Data - by Fish - 03-11-2022, 03:55 PM
RE: DNS Problems with Mobile Data - by drh - 03-13-2022, 02:41 AM
RE: DNS Problems with Mobile Data - by Fish - 03-13-2022, 03:37 AM
RE: DNS Problems with Mobile Data - by TRS-80 - 03-10-2022, 11:45 PM
RE: DNS Problems with Mobile Data - by biketool - 04-17-2022, 09:35 AM
RE: DNS Problems with Mobile Data - by TRS-80 - 04-30-2022, 04:42 PM
RE: DNS Problems with Mobile Data - by biketool - 04-30-2022, 11:46 PM
RE: DNS Problems with Mobile Data - by Ryu - 10-29-2022, 06:33 AM
RE: DNS Problems with Mobile Data - by treebeard - 10-29-2022, 09:16 AM
  Pinephone seems tobe using 4G data instead of Wifi data grump_fiddle_reinstall 7 4,953 02-20-2025, 02:47 PM
Last Post: puffchumpy
  Mobile internet via cellular network mostly not working Anna 18 20,250 01-19-2024, 02:59 AM
Last Post: anonymous
  Stability problems with 6.1 kernel Zebulon Walton 9 6,959 05-12-2023, 08:09 AM
Last Post: zetabeta
  4G data on default startup / boot dcinoz 1 2,241 04-29-2023, 11:24 PM
Last Post: dcinoz
  Block firefix-esr-mobile-config from (re)installing itself grump_fiddle_reinstall 3 3,867 01-07-2023, 09:36 AM
Last Post: dcarvil
Exclamation No modems were found: No mobile data, no 2G anonymous 2 3,509 12-26-2022, 06:46 PM
  very slow processing of MMS received via Ting (T-Mobile) treebeard 6 6,363 12-01-2022, 09:18 AM
Last Post: traut
  Problems after Tow-Boot Dinosaur1946 3 3,673 09-18-2022, 12:48 AM
Last Post: SpaggettiCoder
  Will this battery-saving script cause problems? rp3 1 2,598 08-28-2022, 02:00 PM
  Tow-boot problems and restoring uboot Zebulon Walton 15 15,160 08-14-2022, 11:09 AM
Last Post: shulamy
