DNS Problems with Mobile Data
(02-22-2022, 04:16 AM)arno_nuehm Wrote:
(02-21-2022, 05:23 PM)anonymous Wrote:
(02-20-2022, 08:04 AM)arno_nuehm Wrote: Hello there,
is anyone else facing DNS problems using mobile data after the latest Network Manager update to v1.35.91-1?
I can ping 8.8.4.4 for example but opening a homepage in a browser is not working.
No problems with Wifi though...
Thanks in advance!
Yes I have the same problem since about 24 hours. Thank you for mentioning it here. My Pinephone is my daily driver, I really need to make it work anew.
I reported this bug here:
https://gitlab.freedesktop.org/NetworkMa...issues/931
Please mention your workarounds.
Thanks for the bug report. I think, the problem is that the latest Bookworm version of Network Manager is not forwarding the DNS server adress from mobile networks to the system as it does with the Wifi DNS.
And since I don't like downgrading, here is my workaround as mentioned above from Zebulon Walton:
sudo apt install resolvconf
sudo nano /etc/resolvconf/resolv.conf.d/head
# add "nameserver IP-ADRESS" --> 9.9.9.9 for quad9 for example
sudo systemctl restart resolvconf.service
sudo systemctl restart systemd-resolved.service
That did the trick for me without downgrading.
Cheers
Yes I saw the same trick here:
https://debian-facile.org/doc:systeme:resolv.conf
"Il suffit de mettre les paramètres que l'on veut dans le fichier « head » présent ici : /etc/resolvconf/resolv.conf.d/
Dès lors, ce sont ces paramètres qui seront repris comme prioritaires dans le resolv.conf" which means
"Just put the parameters you want into the "head" file here: /etc/resolvconf/resolv.conf.d/
From then on, these parameters will be taken up as priorities in the resolv.conf"
I'm going to use these DNS:
https://www.fdn.fr/actions/dns/
P.S: It works as expected, many thanks Smile
DNS Problems with Mobile Data - by arno_nuehm - 02-20-2022, 08:04 AM
RE: DNS Problems with Mobile Data - by jsch - 02-20-2022, 11:05 AM
RE: DNS Problems with Mobile Data - by dukla2000 - 02-20-2022, 12:14 PM
RE: DNS Problems with Mobile Data - by arno_nuehm - 02-20-2022, 02:43 PM
RE: DNS Problems with Mobile Data - by user641 - 02-20-2022, 06:05 PM
RE: DNS Problems with Mobile Data - by dachalife - 02-21-2022, 11:54 AM
RE: DNS Problems with Mobile Data - by anonymous - 02-21-2022, 05:23 PM
RE: DNS Problems with Mobile Data - by arno_nuehm - 02-22-2022, 04:16 AM
RE: DNS Problems with Mobile Data - by anonymous - 02-22-2022, 06:04 AM
RE: DNS Problems with Mobile Data - by moxx - 02-22-2022, 08:01 AM
RE: DNS Problems with Mobile Data - by powo01 - 02-23-2022, 05:58 AM
RE: DNS Problems with Mobile Data - by arno_nuehm - 03-03-2022, 01:58 AM
RE: DNS Problems with Mobile Data - by Zdenek - 03-03-2022, 03:31 PM
RE: DNS Problems with Mobile Data - by user641 - 03-03-2022, 04:16 PM
RE: DNS Problems with Mobile Data - by arno_nuehm - 03-04-2022, 03:36 AM
RE: DNS Problems with Mobile Data - by user641 - 03-05-2022, 07:43 AM
RE: DNS Problems with Mobile Data - by Fish - 03-11-2022, 03:55 PM
RE: DNS Problems with Mobile Data - by drh - 03-13-2022, 02:41 AM
RE: DNS Problems with Mobile Data - by Fish - 03-13-2022, 03:37 AM
RE: DNS Problems with Mobile Data - by TRS-80 - 03-10-2022, 11:45 PM
RE: DNS Problems with Mobile Data - by biketool - 04-17-2022, 09:35 AM
RE: DNS Problems with Mobile Data - by TRS-80 - 04-30-2022, 04:42 PM
RE: DNS Problems with Mobile Data - by biketool - 04-30-2022, 11:46 PM
RE: DNS Problems with Mobile Data - by Ryu - 10-29-2022, 06:33 AM
RE: DNS Problems with Mobile Data - by treebeard - 10-29-2022, 09:16 AM
  Pinephone seems tobe using 4G data instead of Wifi data grump_fiddle_reinstall 7 4,953 02-20-2025, 02:47 PM
Last Post: puffchumpy
  Mobile internet via cellular network mostly not working Anna 18 20,250 01-19-2024, 02:59 AM
Last Post: anonymous
  Stability problems with 6.1 kernel Zebulon Walton 9 6,959 05-12-2023, 08:09 AM
Last Post: zetabeta
  4G data on default startup / boot dcinoz 1 2,241 04-29-2023, 11:24 PM
Last Post: dcinoz
  Block firefix-esr-mobile-config from (re)installing itself grump_fiddle_reinstall 3 3,867 01-07-2023, 09:36 AM
Last Post: dcarvil
Exclamation No modems were found: No mobile data, no 2G anonymous 2 3,509 12-26-2022, 06:46 PM
  very slow processing of MMS received via Ting (T-Mobile) treebeard 6 6,363 12-01-2022, 09:18 AM
Last Post: traut
  Problems after Tow-Boot Dinosaur1946 3 3,673 09-18-2022, 12:48 AM
Last Post: SpaggettiCoder
  Will this battery-saving script cause problems? rp3 1 2,598 08-28-2022, 02:00 PM
  Tow-boot problems and restoring uboot Zebulon Walton 15 15,160 08-14-2022, 11:09 AM
Last Post: shulamy
