Manjaro Plasma Beta and Cellular Data Service
(03-01-2022, 07:15 AM)acrux Wrote: Confirmed, it seems to be not fixed yet in PinePhone PlaMo. You can report your findings to above mentioned bugs Big Grin
I guess the fix is targeted to beta 11?
Yes, it's much better in Beta 11.  Initially however, I used the drop down menu to disable mobile data, but when I went to system settings and cellular network, it disagreed, the check box that says mobile data was checked, and it said "On".  I uncheck that box as well, and it seems to be working correctly, but it's a little disconcerting to think that either the drop down menu or the system settings may be deceiving you.
***   Don't be a minion in the (i)droid army   ***
RE: Manjaro Beta and Cellular Service - by acrux - 02-11-2022, 05:22 AM
RE: Manjaro Plasma Beta and Cellular Data Service - by Fred Zyphal - 03-17-2022, 05:50 PM
  Wi-Fi Issues (Plasma and Lomiri) PineSupporter 11 21,959 02-20-2026, 12:16 PM
Last Post: krissprat73
  PinePhone Beta Edition will not boot from MicroSD card Timothy_Ecc 10 19,697 10-04-2024, 12:01 AM
Last Post: spazz
  Pinephone with KDE plasma - Battery drain when phone is not used Daniello 1 4,034 07-03-2024, 08:38 PM
  debugging issue realted to iso image wth extra data eror penguins_rule 3 5,494 06-18-2024, 01:18 AM
Last Post: waderatke
  what is wrong with KDE plasma beta15 RC4? Uturn 8 10,308 10-02-2023, 05:07 AM
Last Post: Uturn
  Manjaro: Settings doesnt open nbh 0 3,322 09-24-2023, 05:25 PM
Last Post: nbh
  Can't get ring on Manjaro Pine Phone thorensjubilee 12 17,044 06-09-2023, 04:40 AM
Last Post: thorensjubilee
  Is Manjaro ARM a Rolling Release? jojuma 4 7,092 05-10-2023, 09:27 PM
  Where Does Manjaro Phosh Store Its Custom Keystrokes? jakfish 0 3,675 04-25-2023, 09:49 AM
Last Post: jakfish
Exclamation My short experience with Manjaro Plasma Mobile anonymous 10 16,433 03-02-2023, 07:25 PM
