Tow-Boot, a new U-Boot option for Pinephone Pro and other devices
#55
(04-25-2022, 02:59 AM)wibble Wrote:
(04-23-2022, 09:28 AM)3460p Wrote:
(04-22-2022, 07:39 AM)wibble Wrote: You're using a PinePhone not a Pro, so the boot search order is uSD then eMMC. If you got the multiboot menu then your uSD still has p-boot on it, and this was run before it even looked at the eMMC. tow-boot wasn't involved in that one at all.
You’re quite right - my apologies, I had thought that I’d managed to do what I described above with the PP starting on a red LED as well as enabling me to access USB mode with the blue LED Up volume button (i.e. indicating that Tow-Boot was still the functioning bootloader) but I just tried to replicate that and my PP started with a green LED then displayed Megi’s multiboot menu so I can only assume I got slightly muddled when I first tried this late into the night...
Ok so there’s no way of having ones main OS on the microSD card, Megi’s multiboot on the eMMC and be able to switch between the two without removing the microSD card?
I think you could do that in two ways, both using p-boot. One is to remove the bootloader from the uSD so that the process skips the uSD and uses the p-boot on the eMMC. The other is to install p-boot on the uSD. In either case you'll need to check the p-boot docs to see what config changes you need to make to p-boot to provide the extra boot options.
Hmm that’s effectively what I thought I’d achieved by putting a more recent build of Mobian on the microSD because IIUC Mobian’s removed the bootloader from their recent builds since they’re now relying on Tow-Boot being in place...but yeah as we’ve already discussed, Megi’s multiboot currently only works with p-boot and Tow-Boot doesn’t recognise p-boot as something into which to boot.
I’ll see what I can manage with getting p-boot on the microSD!
RE: Tow-Boot, a new U-Boot option for Pinephone Pro and other devices - by 3460p - 05-05-2022, 01:22 PM
  bookworm vs trixie discussion for mobian in pinephone pro. zetabeta 21 15,453 10-20-2025, 07:01 AM
  Bare metal on Pinephone Pro alain 0 2,909 08-19-2025, 07:58 AM
Last Post: alain
  Seeking Contributors: Apache NuttX Real-Time Operating System for PinePhone Pro lupyuen 4 5,573 08-19-2025, 01:38 AM
Last Post: geometrylitegame12
Star FreeBSD developer build for PinePhone Pro teekay 1 1,785 05-03-2025, 11:02 AM
  freeBSD is booted on pinephone pro with console output zetabeta 5 3,579 04-18-2025, 12:56 AM
Last Post: teekay
  How to Clone Kali Linux to PinePhone Pro with Terabyte IFW TOF 2 3,459 02-26-2025, 02:15 AM
Last Post: TOF
  July 1 upgrade of Mobian Bookworm boot loops. mburns 9 6,236 02-25-2025, 08:27 AM
  Anyone gotten latest Ubuntu Touch to work on PinePhone Pro? dchang0 4 4,826 12-22-2024, 04:21 PM
Last Post: dchang0
  Installing r2kaw and Tow-Boot to the SPI ethical_haquer 10 6,037 12-19-2024, 05:22 PM
Last Post: dukla2000
  tow-boot installation problem techariah 4 5,961 12-04-2024, 10:32 AM
Last Post: zetabeta
