soundcard pinephone mobian
(02-06-2022, 12:20 PM)wibble Wrote: You did ask for a real good one, and didn't specify price ;-) I don't know enough about DJing to know what features you need, what might be useful but isn't really necessary, and what's no use at all. Mic inputs? Balanced or single ended inputs and outputs? Physical knobs rather than virtual controls? Headphone outputs?
https://linuxmusicians.com/ should give you an idea about whether most interfaces work, or if people have compatibility problems. https://audiosciencereview.com has measurements for some of them so you can see how good the inputs and outputs are - it doesn't say much else about features or linux compatibility unless someone comments on them. The MOTU M2 and M4 apparently work well with kernel 5.11 or later. Gen1 and Gen2 Focusrite Scarletts should work well, and low channel count Gen3 might be ok. At the really cheap end I'd expect the Fun Generation UA-202 to work since the Behringer UCA202 does, and they use the same chipset.
Hey, thanx a lot for a lot of great links........I think I' ll go for the MOTU M2........and tell my experience...........
soundcard pinephone mobian - by benedikt55 - 02-04-2022, 07:55 AM
RE: soundcard pinephone mobian - by wibble - 02-04-2022, 09:20 AM
RE: soundcard pinephone mobian - by benedikt55 - 02-06-2022, 04:58 AM
RE: soundcard pinephone mobian - by wibble - 02-06-2022, 12:20 PM
RE: soundcard pinephone mobian - by benedikt55 - 02-06-2022, 01:21 PM
  bookworm vs trixie discussion for mobian in pinephone regular. zetabeta 77 41,741 10-27-2025, 10:19 AM
  cryptocurrency on mobian/pinephone biketool 35 57,764 10-08-2025, 06:21 AM
  Mobian MMS/SMS text problem bcnaz 16 26,764 09-15-2025, 02:42 AM
Last Post: georgegohl888
  XLibre for Mobian Hiraghm 1 2,130 06-30-2025, 01:38 AM
Last Post: Haroldkent
  Axolotl on PinePhone / Mobian arno_nuehm 223 272,508 06-25-2025, 01:19 PM
Last Post: anonymous
  VoIP account on mobian dialer j_s 0 1,905 06-15-2025, 04:19 PM
Last Post: j_s
  Mobian Pinephone Notification LED biketool 2 2,438 06-07-2025, 03:19 PM
  Vivaldi Web browser nearly native for Mobian biketool 3 2,856 05-06-2025, 02:19 AM
  mobian calamares fail merom 2 2,852 04-29-2025, 02:10 PM
Last Post: mdk
  Pinephone seems tobe using 4G data instead of Wifi data grump_fiddle_reinstall 7 4,953 02-20-2025, 02:47 PM
Last Post: puffchumpy
