soundcard pinephone mobian
(02-04-2022, 09:20 AM)wibble Wrote: It's confirmed working with the RME Babyface.
https://forum.pine64.org/showthread.php?tid=13884
It should work with pretty much any audio interface that works with linux, and since you're using the powered dock the power requirements shouldn't be a problem. That covers most USB DACs. If you're after interfaces with inputs or multiple channels you'll need to do a bit more compatibility research. What are your requirements?
thank you, the link is interesting, but a babyface is real expensive.................my requirements are always the same: a great sound quality! And for an easyier DJing interfaces with inputs/ multiple channels would be great..............any recommendations?
soundcard pinephone mobian - by benedikt55 - 02-04-2022, 07:55 AM
RE: soundcard pinephone mobian - by wibble - 02-04-2022, 09:20 AM
RE: soundcard pinephone mobian - by benedikt55 - 02-06-2022, 04:58 AM
RE: soundcard pinephone mobian - by wibble - 02-06-2022, 12:20 PM
RE: soundcard pinephone mobian - by benedikt55 - 02-06-2022, 01:21 PM
  Mobian repository status henrythemouse 16 8,748 04-10-2024, 10:02 AM
Last Post: diederik
  bookworm vs trixie discussion for mobian in pinephone regular. zetabeta 15 2,005 03-25-2024, 09:07 AM
Last Post: anonymous
  cant verify mobian image at website gnugpg penguins_rule 0 132 03-18-2024, 08:54 PM
Last Post: penguins_rule
  unofficial kali linux for pinephone help needed pinesmell 5 3,630 01-08-2024, 02:50 PM
Last Post: ERPlegend
  mobian installed to eMMC - how to install tow-boot grump_fiddle_reinstall 6 1,995 11-22-2023, 11:46 AM
Last Post: aLoop100o
  What actions needed to keep on mobian testing user641 3 1,823 09-05-2023, 06:44 AM
  Mobian boot failed with zstd message after upgrade. Mahgue 0 633 09-01-2023, 11:29 AM
Last Post: Mahgue
  how to update mobian over tor vusra 13 6,898 07-09-2023, 08:57 PM
Last Post: vusra
  opensnitch outbound firewall now works on mobian vusra 2 1,899 07-09-2023, 01:37 AM
Last Post: vusra
  Using Nativefier on PP64 with Mobian paulcarton 0 631 07-05-2023, 03:57 AM
Last Post: paulcarton
