Howto: Pinetab Screen Replacements (+ Pictures)
(02-02-2022, 04:56 AM)barray Wrote: Thank you @RTP , I'll need to open mine up again to replace the motherboard some day. The WiFi in mine bricked itself for no reason at all. I have also been waiting for quite some time for the M.2 port to add an SSD inside. One day hopefully the Tab will get some love.
Quote:Firstly, I don't recommend ever taking apart your Pinetab unless you absolutely have to.
This is really sad. The entire point of owning an open source device is that you should be encouraged to open it up.
Using a clam shell for such a large display was a mistake - it is just asking to bend the display. It would have been infinitely better to have some M2 screws holding it in place instead.
Opened mine maybe around 20 or so times for different exploratory adjustments without so much as a scratch. Smile
It's absolutely a great device for opening/modification options! The cover design works well coming off and going back on without damage. But I don't know the limitations in screen, and try to play it safe and recommend that.
Only wrote initial warning after reading where others reported breaking their screens and so was hesitant to openly encourage it.
But it really is safe if someone is careful and follows the recommendations IMHO.
I think the way I open it is very safe. But there's always a concern when dealing with screens like this and a cover that is less "pop off" than the Pinephone design Wink
Following the "peel the cover off the screen, not the screen off the cover" advice is best IMHO.
I secretly encourage everyone to open it and tinker! It's really not hard to open! Big Grin
Thanks for your feed back! Smile
- RTP
"In the beginner's mind there are many possibilities, in the expert's mind there are few." -Shunryu Suzuki
[ Pinephone Original | Pinetab v1 / v2 Enjoyer ]
Linux Device Privacy / Security Playlist
RE: Howto: Pinetab Screen Replacements (+ Pictures) - by RTP - 02-02-2022, 04:03 PM
  cracked screen and repair elix 0 1,489 03-07-2025, 01:40 PM
Last Post: elix
  Not able to power on PineTab anymore zkajdan 4 3,530 01-12-2025, 10:38 PM
Last Post: vatin
  Pinetab2 screen removal Corconegre 5 4,727 01-10-2024, 08:08 AM
Last Post: stozi
Question Will Pinetab 2 spare parts be available? vatin 6 5,672 12-09-2023, 01:31 AM
  ?brighter screen replacement for pinetab (>1600 nits) dynobang 0 1,840 09-28-2023, 01:06 PM
Last Post: dynobang
  [Tutorial] How to overclock Pinetab 2 Darth-Apple 0 2,604 09-25-2023, 08:45 AM
Last Post: Darth-Apple
  External Reset button on PineTab V? michaelengel 0 1,663 09-18-2023, 06:31 AM
Last Post: michaelengel
  PineTab2 screen won't turn back on until reboot KelsonV 3 3,710 08-23-2023, 09:08 AM
Last Post: diederik
  Pinetab 2 screen no longer coming on Fibonacci 9 8,949 06-30-2023, 08:26 AM
Last Post: Purple_Illusion
  Pinetab completely bricked Saksmito 8 7,330 06-10-2023, 04:23 PM
Last Post: fxc
