Powering Pinecil using an Artis 65W laptop adapter
(02-02-2022, 05:54 AM)werty37 Wrote: Hi
The manufacturer has confirmed that it is not a PD-capable charger.
https://www.amazon.in/ask/questions/Tx1D...pmw_al_hza
Quote:I assume it is a PD-capable charger, so Pinecil can request 20V and it is able to provide up to 3.25A for Pinecil - generally it should be a perfect fit.
@VaZso Do you still think that I can use it to power the Pinecil and hopefully not damage it?
It should be either a QC or PD-capable charger and both should be okay for Pinecil.
For QC, my Baseus chargers needed a timeout setting for PD negotiation timeout which is part of the latest firmware update but it works well by setting this timeout to 15.
As of QC protocol, there are a very few chargers which support 20V over QC (although I have such a charger, so it exists).
However, Type-C capable notebooks work over PD protocol, so if this charger really supports "5V/2.4A, 9V/3A, 12V/3A, 15V/3A, 18V/3A,20V/2.25A, and 20V/3.25A, Max Power Output: 65Watts" as they state, it should be a PD-capable charger (power supply).
However, I am not surprised at anything since I saw there are "notebook chargers" which have 12V output over Type-C connector without any negotiation (they should not exists anyway).
As of seller replies who has recommended a 45W or 30W charger for something which would need 20V * 3A = 60W, I would not think to know too much information about the product to be sold...
If it is either a QC or PD power supply, it should work... but based on the supported voltages, technically it should be one of them (definitively PD for notebooks).
However, it is another question if the power supply is really can provide 65W power output...
RE: Powering Pinecil using an Artis 65W laptop adapter - by VaZso - 02-02-2022, 04:35 PM
  Connecting a power supply to the Pinecil jon_bondy 1 340 02-29-2024, 07:37 PM
Last Post: Okedokey
  Crippling noise from inside pinecil during a few minutes high power soldering. dreieck 2 760 01-31-2024, 12:34 AM
Last Post: suga7
Question Pinecil Tempaerature Reading jumps to Y400°C when active but stays normal when cold H3wastooshort 0 355 12-24-2023, 05:45 PM
Last Post: H3wastooshort
  Asus laptop power supply can also power Pinecil biketool 9 8,196 11-17-2023, 12:57 PM
Last Post: killingmesmalls
  Mass problem Pinecil V2 Harrysteed 0 646 11-02-2023, 09:11 AM
Last Post: Harrysteed
Question Pinecil v2 power cycles at higher voltages? clemon79 2 1,270 10-09-2023, 10:10 PM
Last Post: clemon79
  PD resets during heat up tip [Pinecil V2] Neitron4ik 2 1,531 10-09-2023, 01:22 AM
Last Post: Neitron4ik
  [Hackaday Article] All About USB-C: Pinecil Soldering Iron vajak 1 1,428 02-02-2023, 11:45 AM
Last Post: VaZso
  Brand new Pinecil v2 won't boot on PD jhutch 1 2,226 12-14-2022, 01:03 AM
Last Post: River
  Survey on Pinecil Tips, Please fill out River 0 1,242 11-06-2022, 02:43 AM
Last Post: River
