Disable on screen keyboard permanently.
(06-08-2022, 08:25 PM)SwordfishII Wrote: echo -n 1500000 | sudo tee /sys/class/power_supply/axp20x-usb/input_current_limit
A side note, you can close force close kgx with "kill $PPID" at the end of the script.
Wish I could get around having to enter my password for the sudo part though
Check the NOPASSWD option in /etc/sudoers - you can use it to allow specific commands to be run without requiring the password. Something like:
your_user_name ALL=(ALL) NOPASSWD:/usr/bin/tee /sys/class/power_supply/axp20x-usb/input_current_limit,some_other_command_you_want
RE: Disable on screen keyboard permanently. - by wibble - 06-09-2022, 04:47 AM
  icon keyboard chris_02 3 300 02-09-2024, 08:53 AM
Last Post: 3x5co
  Keyboard not popping up on QT apps 3x5co 1 161 02-08-2024, 11:45 PM
  Screen auto-rotation sensitivity mdk 0 213 12-26-2023, 06:08 AM
Last Post: mdk
  Keyboard keeps disappearing the moment it's touched jojuma 1 432 10-29-2023, 08:34 AM
Last Post: walter1950
  New keyboard issue sandspur 29 11,639 10-05-2023, 02:27 AM
  how to disable ipv6 at kernel level with towboot? vusra 2 822 07-09-2023, 01:25 AM
Last Post: vusra
  Unable to do initial setup of Weather due to keyboard LibrePhoneUser 2 1,019 07-07-2023, 03:29 AM
Last Post: jojuma
  Screen stay black unless power key pressed short freelectro 0 601 06-24-2023, 01:55 PM
Last Post: freelectro
  Unsuspend → Black screen mdk 15 4,777 06-22-2023, 11:20 AM
Last Post: Melechtna
  Lock screen question: always squeekboard tuxcall 1 1,152 02-02-2023, 08:51 PM
Last Post: Haibara23
