Disable on screen keyboard permanently.
The problem I have had is similar but would require the same fix. I resize my desktop display to 175% to better fit all the icons onto the screen without scrolling. I use the apply to make the change but when the phone is turned off or rebooted the settings have not been saved. A permanent save feature would be helpful. Thanks for your comment. I have your same problem when I use my bluetooth keyboard with my phone. Each time I begin a new session with the keyboard I have to go to settings and disable the onscreen keyboard. Thanks for your comment.
RE: Disable on screen keyboard permanently. - by gilwood - 02-04-2022, 01:09 PM
  icon keyboard chris_02 3 412 02-09-2024, 08:53 AM
Last Post: 3x5co
  Keyboard not popping up on QT apps 3x5co 1 239 02-08-2024, 11:45 PM
  Screen auto-rotation sensitivity mdk 0 268 12-26-2023, 06:08 AM
Last Post: mdk
  Keyboard keeps disappearing the moment it's touched jojuma 1 499 10-29-2023, 08:34 AM
Last Post: walter1950
  New keyboard issue sandspur 29 12,386 10-05-2023, 02:27 AM
  how to disable ipv6 at kernel level with towboot? vusra 2 895 07-09-2023, 01:25 AM
Last Post: vusra
  Unable to do initial setup of Weather due to keyboard LibrePhoneUser 2 1,091 07-07-2023, 03:29 AM
Last Post: jojuma
  Screen stay black unless power key pressed short freelectro 0 649 06-24-2023, 01:55 PM
Last Post: freelectro
  Unsuspend → Black screen mdk 15 5,135 06-22-2023, 11:20 AM
Last Post: Melechtna
  Lock screen question: always squeekboard tuxcall 1 1,221 02-02-2023, 08:51 PM
Last Post: Haibara23
