SD card slot specs
I could not find detailed specifications wrt the SD card slot, only that it can use SDHC and SDXC cards. Does anyone know if the SD card slot supports UHS-II bus class (which has "two rows of contacts" on the UHXC card I believe)? Or, to be more specific of my needs, is it realistic to hope for SD card *write* speeds of 100MB/s?
I ask as I would like to use a class UHS-II and v90 SDXC card to stream from a StructureCore sensor (occipitals depth sensor). The scanner do work on the PinePhone PRO - I have successfully compiled and run it on the PRO. Output is about 9fps, twice the result for the original PinePhone, however, also with more computationally intensive options available. I only guess the reason is that computational power increased more than data throughput?
SD card slot specs - by frimmel - 01-27-2022, 10:30 AM
RE: SD card slot specs - by frimmel - 01-27-2022, 02:46 PM
RE: SD card slot specs - by dukla2000 - 01-27-2022, 03:09 PM
RE: SD card slot specs - by bcnaz - 01-27-2022, 09:48 PM
  How to remove the sim card liberty1234 7 10,571 07-17-2024, 09:57 AM
Last Post: Blackheart
  Anyone yet received replacement sim/sd card holder tckosvic 19 20,698 06-16-2023, 12:20 PM
Last Post: fxc
Photo My PinePhone Pro does not read the micro SD card at all. tux_life 7 7,462 03-26-2023, 02:55 AM
Last Post: tux_life
  PinePhone Pro Motherboard with sim card holder tckosvic 1 3,262 08-22-2022, 06:42 PM
  Warning!!- sim card adapter destroyed my sim card holder on my pine phone pro ANDROID2468 11 15,618 06-15-2022, 02:32 AM
Last Post: fxc
  Replace PPP sim card/sd card slot hardware tckosvic 5 7,585 03-13-2022, 12:20 PM
Last Post: tckosvic
  SD Card insertion depth nristen 4 5,925 02-03-2022, 01:27 PM
Last Post: nristen
  Bent SD card pin bhboyle 5 7,399 02-03-2022, 09:54 AM
Last Post: kqlnut
