PineTime re-connect to PInephone
So some things I learned today as this was my first day using the pinetime all day.
The issue actually seems to be with the pinephone itself. First off Amazfish is a far better companion app as it is working even when the app is not open. So start by using that app instead of siglo
My firmware is 1.2.0 infinitime so maybe I am back on firmware that is something I will try.
When the pinephone goes to sleep (suspends) amazfish actually tells you your phone is going to suspend soon then a short time later the pinetime disconnects. The issue is when the pinetime wakes back up from a message or call or you just turn your screen on the bluetooth does not seem to re connect.
What I found is when you wake from suspend if you tap the bluetooth off then on in the quick access pull down menu a min or two later the phone will reconnect to the watch.
Currently I have completely turned off suspend on my pinpephone and my watch has been connected for the last hour or so. This obviously comes at a price of battery life.
I am wondering if anything can be done to either leave just Bluetooth on during suspend or have an immediate reset of Bluetooth on wake for connection.
PineTime re-connect to PInephone - by kmsgli - 12-28-2021, 05:35 PM
RE: PineTime re-connect to PInephone - by wibble - 12-29-2021, 07:47 AM
RE: PineTime re-connect to PInephone - by kmsgli - 12-29-2021, 02:41 PM
RE: PineTime re-connect to PInephone - by wibble - 12-30-2021, 05:25 AM
RE: PineTime re-connect to PInephone - by kmsgli - 12-30-2021, 02:35 PM
RE: PineTime re-connect to PInephone - by kmsgli - 12-30-2021, 08:05 PM
RE: PineTime re-connect to PInephone - by kmsgli - 01-01-2022, 08:05 PM
  Open-Source Support for PineTime LTE (eSIM) emilyjohnson63 2 2,230 11-01-2025, 05:55 PM
Last Post: euiccc2025
  Migrating to PineTime from a Fitbit dhdurgee 0 2,928 09-25-2025, 12:41 PM
Last Post: dhdurgee
  Brand new sealed Pinetime boot loop elver 0 9,918 09-10-2025, 06:41 AM
Last Post: elver
  Pinetime Black Screen philipallmon 1 4,371 07-30-2025, 11:44 PM
Last Post: karthick
  ? Introducing RoutineHero: A PineTime Smartwatch for Kids' Routines + Companion App oscar-gardiazabal 2 1,316 07-29-2025, 04:49 AM
Last Post: oscar-gardiazabal
  PineTime charging issues - connecting pins black gsoundsgood 2 2,495 09-15-2024, 02:59 PM
Last Post: gsoundsgood
  How do I clear all personal data from the pinetime smartwatch? taltamir 6 3,911 08-22-2024, 10:34 AM
Last Post: taltamir
  [SOLVED] Gadgetbridge not pairing with pinetime zoof 3 7,902 06-25-2024, 12:21 AM
Last Post: Amen
  PineTime at FOSDEM jmlich 5 4,736 02-07-2024, 11:48 PM
  PineTime turns off when removed from cradle tynstar 0 1,738 01-31-2024, 11:57 AM
Last Post: tynstar
