Cannot Create Profile - Cannot even Flash OS
You don't have to set the phone in any mode or finish any profile setting to flash the OS! The bootloader is open by design. Please read the wiki link I have posted!
It's likely that you will have the problems on creating profile on most OSes, if the scaling isn't right yet and its different, so I can't help with what you have to do exactly to overcome that. If your OS is Manjaro it's more likely that you get the right answer in the Manjaro section.https://forum.pine64.org/forumdisplay.php?fid=130
On my PineTab on Mobian I just pressed enter on every window and did all settings afterwards.
I feel your pain having a new device and can't get it to work! Cool down, try to overcome the profile issue and if you feel, you want to install a new OS, read the wiki first!!! It's really easy, since you have done it ones...
RE: Cannot Create Profile - Cannot even Flash OS - by guenther - 12-17-2021, 03:52 AM
  This is how you flash to eMMC easily Luke 49 80,545 12-25-2022, 05:13 PM
Last Post: fxc
  Tow Boot - How to Flash a New OS? arkadione 3 2,740 06-15-2022, 04:10 PM
Last Post: kmsgli
  no emmc after flash ragele 3 2,195 05-30-2022, 04:26 AM
Last Post: fxc
  Cannot even create profile because screen won't rotate2 absolutenoob 5 3,549 02-28-2022, 01:00 PM
Last Post: Jetpac
  Best way to manage multiple OS installations (backup, flash) 3x5co 2 3,002 02-08-2021, 09:28 PM
Last Post: C0ffeeFreak
  flash sd card from pinephone when you've just booted from it moodroid 1 2,333 11-14-2020, 06:13 AM
Last Post: nightranger73
  pinephone won't boot after dd flash try maybl8 10 11,297 10-16-2020, 12:34 PM
Last Post: ThrillGates
Question Stuck trying to flash phone zeroed 1 2,717 09-06-2020, 10:02 AM
Last Post: RodMyers
  Unable create libertine container aberrio 3 4,369 07-25-2020, 02:32 PM
Last Post: wibble
