Need help! Can't get device mode to work.
I'm running Debian on rockpro64, I want to setup rndis when device is plug into a linux host. I have modified the device tree to have USB-c port as peripheral. I have also setup configfs according to a lot of posts on the net, but every time I plug it in, linux host would give this error:
[Dec10 14:40] usb 1-2: new full-speed USB device number 57 using xhci_hcd
[  +0.128029] usb 1-2: device descriptor read/64, error -71
[  +0.236017] usb 1-2: device descriptor read/64, error -71
[  +0.235946] usb 1-2: new full-speed USB device number 58 using xhci_hcd
[  +0.128047] usb 1-2: device descriptor read/64, error -71
[  +0.235999] usb 1-2: device descriptor read/64, error -71
[  +0.108108] usb usb1-port2: attempt power cycle
[  +0.411868] usb 1-2: new full-speed USB device number 59 using xhci_hcd
[  +0.000146] usb 1-2: Device not responding to setup address.
[  +0.207999] usb 1-2: Device not responding to setup address.
[  +0.207841] usb 1-2: device not accepting address 59, error -71
[  +0.127874] usb 1-2: new full-speed USB device number 60 using xhci_hcd
[  +0.000143] usb 1-2: Device not responding to setup address.
[  +0.208144] usb 1-2: Device not responding to setup address.
[  +0.207847] usb 1-2: device not accepting address 60, error -71
[  +0.000175] usb usb1-port2: unable to enumerate USB device
I have bind fe800000.usb to UDC in configfs, but seems like whatever I change in configfs won't affect the result, as if configfs has nothing to do with the usb port.
I found someone else also had similar issue in another post on this forum, but there is no detail whether he found a solution or what the solution was.
Can anyone help?
Need help! Can't get device mode to work. - by scanboy - 12-10-2021, 04:48 PM
  USB3 xhci-hcd in SuperSpeed mode swan 0 2,267 05-11-2023, 05:35 AM
Last Post: swan
  RockPro64 linux console video mode callegar 0 2,060 09-06-2022, 02:32 PM
Last Post: callegar
  Using the PCIe slot of ROCKPro64 as EndPoint mode nonoriri 1 3,070 11-20-2021, 10:53 AM
Last Post: fire219
  slave mode on Rockpro64 Radhika.gabani 1 3,400 09-22-2021, 05:35 AM
Last Post: mahtew
  Linux distro that will work with Kodi? SBCraok 9 16,996 09-18-2019, 02:12 AM
Last Post: mtrcycllvr
  USB device mode tikonen 1 3,961 07-02-2019, 05:49 AM
Last Post: tikonen
Information PCIe -> SATA and NVMe work as of 0.6.59 Luke 13 21,185 08-06-2018, 11:33 AM
Last Post: dukla2000
