Wont charge when powered off, and update question
If you are using the git,, use ./updater,,,, for the 2nd stage, be aware that you have to cd to the git directory
(since updater is in the git directory and not in any path)
The manjaro package had the same software, but setup a little differently,
but you did NOT get it installed so pbp-fwupdate will give you a "file not found" message
This is if I understand your post correctly...........
RE: Wont charge when powered off, and update question - by wdt - 12-09-2021, 01:41 AM
  uboot wont boot to SD card after upgrade jbradley419 7 631 01-19-2024, 02:29 PM
  Brand new Pinebook Pro doesn't boot after Manjaro update johnboiles 8 2,001 12-15-2023, 02:11 PM
  Newbie Question!! oniichann 3 787 10-26-2023, 07:09 AM
  After update, multiple problems, pinebook pro. jd50i 1 970 09-16-2023, 09:41 AM
Last Post: jd50i
  Metis package can't update Mangustis 1 983 02-22-2023, 03:23 PM
Last Post: robocone
  GPIO breakout question pinus_pinea 0 624 01-17-2023, 06:13 AM
Last Post: pinus_pinea
  Keyboard/Touchpad update SH61F83 IC zaphod80013 4 3,147 09-14-2022, 03:56 AM
Last Post: Carl
Big Grin EASY SOLUTION for Manjaro "Missing Keys" Update and Install Failure Zoroaster-Z 0 1,366 08-14-2022, 09:01 PM
Last Post: Zoroaster-Z
Question Pinebook Pro shows only bright white screen when powered on Sean Whitton 3 1,889 07-22-2022, 01:19 PM
  Ring around screen following update tylerjohnson3208 2 2,010 05-10-2022, 01:52 AM
Last Post: diyagabriel
