Just purchased a used PBP (with no eMMC!) - any tips for a new user?
using the eMMC/usb adapter, you can flash an OS directly on to your eMMC
(There are some boot instructions on the factory eMMC, those will not be included in most of todays OSes.)
Running from the sd card is not terrible, and it is a great way to try multiple OSes, before installing to the eMMC.
If you do buy a new eMMC from the Pine64 Store, I would suggest getting the eMMC to usb adapter at the same time,
It is only $5. ($4.99) and it may prove useful in the future.
      LINUX = CHOICES
         **BCnAZ**
               Idea
   Donate to $upport
your favorite OS Team
RE: Just purchased a used PBP (with no eMMC!) - any tips for a new user? - by bcnaz - 12-04-2021, 03:14 AM
  Happy eMMC and SDcard OS usage for Pinebook Pro Newbies... Paulie420 42 59,900 11-20-2023, 06:22 PM
  I'm booting from NVME but I want to switch back to eMMC acruhl 4 1,480 04-23-2023, 06:58 AM
Last Post: acruhl
  Doesn’t power on after flashing emmc badguru 3 1,233 02-25-2023, 09:00 PM
Last Post: badguru
  eMMC problem with Tow-Boot/u-boot on SPI repa 3 1,695 02-21-2023, 01:49 AM
Last Post: repa
  Partial boot after installing Manjaro on emmc regivanx 11 3,146 02-06-2023, 09:11 AM
  Unable to Boot anything (emmc or SDcard) line72 5 2,003 01-17-2023, 12:07 PM
Last Post: nfms
  What OS have you recently flashed onto PBP eMMC? jcun4128 6 2,353 11-26-2022, 09:39 AM
  Unable to boot from emmc after flashing it rfm83 3 1,769 11-08-2022, 10:59 PM
Last Post: rfm83
  Pinebook picky about which EMMC will boot flatulent_piney 8 3,047 11-05-2022, 06:03 PM
Last Post: ajtravis
  After Flashing eMMC, Will Not Boot Mossbot 5 2,348 09-28-2022, 06:22 PM
