Pacman vs. Discover
for quite a while I used pacman and updated my system in the terminal using:
pacman -Syyu
Discover often failed to update or didn't report available updates.
Then, once during an update, the wifi connection failed and from then on I got an error message after every reboot saying "Offline update failed - Unexpected system error". Neither pacman nor Discover did any updates any more.
After some research I came to the conclusion, it would be easier to completely reinstall the system than keep trying to fix that problem.
I then reinstalled the latest beta release from https://forum.manjaro.org/c/arm/releases/102.
But now it's the other way round: Discover reports and performs updates while pacman says, there's nothing to do.
I feel completely unsure if either of those methods do their job correctly.
My question is: How can I know for sure, if there are any updates and if my system is up to date or not?
Current system data:
KDE Plasma Version: 5.23.2
KDE Frameworks Version: 5.87.0
Qt Version: 5.15.2
Kernel Version: 5.14.17-1-MANJARO-ARM
Thank you!
Pacman vs. Discover - by jojuma - 11-28-2021, 07:34 AM
RE: Pacman vs. Discover - by tckosvic - 11-29-2021, 01:33 PM
RE: Pacman vs. Discover - by acrux - 11-30-2021, 06:01 AM
RE: Pacman vs. Discover - by ryo - 11-30-2021, 10:48 AM
  pacman vs. Discover - again jojuma 4 1,414 05-17-2023, 10:37 PM
  Discover - "He's dead, Jim" jojuma 7 2,509 03-06-2023, 08:11 PM
Last Post: rocket2nfinity
  Can't install software via Discover or Terminal Kimberley van Buyten 2 1,490 06-10-2022, 02:13 AM
Last Post: shulamy
  Keyboard case stopped working on pacman update rotwang 5 3,011 05-07-2022, 09:17 PM
Last Post: rotwang
  Discover crashing (terminal output included). allworlds 1 1,300 05-05-2022, 06:46 AM
Last Post: allworlds
  Discover Error every boot pmprog 0 1,063 11-01-2021, 03:55 AM
Last Post: pmprog
  Ensure Up To Date - Manjaro Plasma Discover Package Manager Sources Linux2thabone 0 1,513 05-05-2021, 11:15 AM
Last Post: Linux2thabone
