07-18-2016, 03:17 PM
Sorry guys for the late response,
in the zip file there are a PDF/OBJ/PDO folders
PDF has some models already in pdf to print and cut manually
OBJ is the simple 3d object
PDO is the files from pepakura design where you can change the cutting settings for your model
Currently I'm exporting from pepakura to silhouette studio and cutting in the machine(if you want the silhouette files I can attach here)
the model I'm using is the one in PDF\fullpine12x12.studio3.pdf as the machine uses a 12inx12in paper
any suggestion please advice
I'm still wondering if it worth having an top lid that I can open sometimes, I'm using it as a TV box only so I don't see any reason to open the top lid, then I glued all the flaps.
