Flat-file database script for pinephone terminal
For anyone interested, the simple flat-file database -- fields.awk -- does run perfectly well on the pinephone terminal, whether it's running Manjaro or Mobian. (Have not tested others) The code can be found here:
SoureForgeLink
Make the file (fields.awk) executable, move it to /usr/local/bin, and change the name to simply "fields" or a short name of your choosing.
Run it once from the command line and it will auto create its own folders .fields/db-archive. You should see a startup display such as this:
FIELDS.AWK:
Flat-file Database Program for Linux systems
® READ from:
(W) WRITE to:
(E) EDIT selected:
(S) SELECT a database
(T) TALLY a column in:
(N) NEW database
(F) Saved-FILES (in .fields/SEARCHES)
(X) Encrypt/Decrypt (files in .fields/db-archive)
(Q) Quit
Typing "N" or "n" will allow you to create one new database file as you're prompted to enter the number of desired fields, and a name for each field.
Enjoy.
Flat-file database script for pinephone terminal - by cabbie001 - 11-21-2021, 06:17 PM
  Movuan distribution for PinePhone merom 5 4,688 07-27-2025, 05:01 PM
Last Post: merom
  baremetal via Zig on PinePhone - JumpDrive help please WhiteHexagon 1 3,040 07-07-2025, 10:33 AM
Last Post: WhiteHexagon
  Latest firmware for PinePhone modem! Subsentient 105 199,644 02-02-2025, 08:47 PM
Last Post: bacydentir85
  Slarm64 on PinePhone [Unofficial Slackware ARM - 64 bit] acid andy 40 54,067 12-28-2024, 12:19 AM
  Office applications for the Pinephone Peter Gamma 2 4,305 09-05-2024, 09:22 AM
Last Post: Peter Gamma
  Struggle to install LibreOffice on the PinePhone Peter Gamma 50 58,521 07-26-2024, 10:35 PM
  Why does Pine64 sabotage office on the Pinephone? Peter Gamma 5 5,604 07-04-2024, 07:34 AM
  Which word processor to choose for the Pinephone? Peter Gamma 16 14,890 06-22-2024, 07:28 AM
  Samba share on the Pinephone? Peter Gamma 0 3,790 06-16-2024, 10:26 PM
  Possible Free Backup Carrier for PinePhone PineFone 0 3,683 06-13-2024, 03:45 PM
Last Post: PineFone
