No incoming SMS. Outgoing SMS, calls and data working.
As of Thursday I've suddenly not been receiving any SMS, and I can't find any errors or changed settings and I did not update anything to cause this to happen.
I am running Manjaro with Phosh, using Chatty for SMS.
From some research, I've come across a couple of similar threads.
https://forum.pine64.org/showthread.php?...&pid=92256 is recent and describes the same issue, the solution they describe is turning off the setting that allows data while roaming. I do not have that setting turned on, and the issue persists.
I've also followed the troubleshooting steps as outlined here:
https://wiki.pine64.org/wiki/PinePhone_F...eceive_SMS
sudo mmcli -m 0 --messaging-list-sms returns "No sms messages were found". My modem is also on 0 though the documentation says it should be 3 for Manjaro. Either way, that fix does not work and does not appear to be relevant.
I've adjusted to multiple configurations of the Verizon APN, all have the exact same issue with the same behavior.
I'm able to connect to the internet, send SMS, and make and receive phone calls but incoming SMS does not seem to work and there appear to be no errors logged, so I'm unsure where the issue lies.
When I use an iOS device I receive messages just fine even without iMessage so there's not an issue with the carrier.
This all happened overnight, I'm not sure what changed or what's causing this and I've tried just about everything I can think of - does anyone have any additional troubleshooting ideas that I could try? Any similar issues?
No incoming SMS. Outgoing SMS, calls and data working. - by HardwarePunk - 11-19-2021, 08:34 PM
  debugging issue realted to iso image wth extra data eror penguins_rule 1 109 03-21-2024, 07:30 PM
Last Post: penguins_rule
  Calls/Texts and External Monitor gregb49 0 607 06-30-2023, 11:38 AM
Last Post: gregb49
  Internal Microphone issue during calls Viktor 6 2,323 03-31-2023, 08:58 AM
Last Post: Viktor
  New issue with phone calls kmsgli 13 6,305 08-15-2022, 01:45 PM
Last Post: Gon
Question Troubleshooting incoming SMS/MMS epiii2 5 2,806 05-18-2022, 11:15 AM
Last Post: epiii2
  Keyboard case stopped working on pacman update rotwang 5 3,017 05-07-2022, 09:17 PM
Last Post: rotwang
  Can't call or receive calls PJK2012 3 2,748 04-26-2022, 03:05 PM
Last Post: PJK2012
  Manjaro Plasma Beta and Cellular Data Service Fred Zyphal 7 4,879 03-17-2022, 05:50 PM
Last Post: Fred Zyphal
  Calls & SMS stopped working Schugy 3 2,290 12-28-2021, 05:00 AM
Last Post: Schugy
  Ctrl-O on virtual keyboard not working in nano PJK2012 3 3,054 11-11-2021, 08:47 PM
Last Post: PJK2012
