No data access on ATT prepaid but my plan has data
(03-25-2022, 08:01 AM)mikehenson Wrote: I have some bad news. Your device came up registered as a Mobile Broadband Device when the Registered IMEI was updated. We do not service Mobile Broadband Devices. The reason you were able to have service before is AT&T had not previously been policing their networks. With the impending 3G Sunset they've begun doing that and you won't be able to use this device with us anymore. You may put your SIM card into another compatible device if you want to continue with us.
The solution to that is to change the IMEI of the Pinephone modem to that of a whitelisted device. Of course you don't want it to be someone else's IMEI, so if you do not have a suitable device on-hand you can pick up a cheap Alcatel flip phone or maybe a used Android phone that is on the list, harvest its IMEI, and just put it in a drawer somewhere. That way you know that the IMEI is not someone else's and will not appear as a duplicate on the network. (Legal issues may apply depending on your jurisdiction.)
RE: No data access on ATT prepaid but my plan has data - by Zebulon Walton - 03-25-2022, 08:15 AM
  How To Access the Pine Phone Auxillary microSD Without Removing Card pinephoneuser22 2 2,069 01-09-2024, 07:02 PM
Last Post: britelite
  how to backup user data? Uturn 1 1,365 08-30-2023, 05:23 AM
  New Zealand network providers mobile data Linux2thabone 3 4,384 08-05-2023, 06:17 AM
Last Post: SchizoPinePhone225
  Cellular Data, Mobian - "No WWAN Adapter Found" justneedsomedatathanks 3 5,662 05-25-2023, 09:03 PM
Last Post: justneedsomedatathanks
  cell data and MMS on AT+T prepaid ossands 2 2,492 10-13-2022, 07:28 AM
Last Post: ossands
Question Mobile data suddenly gone epiii2 1 2,045 05-23-2022, 04:57 PM
Last Post: epiii2
  likely bug, volte does not work when operator side data blockage is activated zetabeta 1 1,940 05-21-2022, 03:03 PM
Last Post: zetabeta
  mobile data jimbusch1 5 5,268 02-24-2022, 02:41 PM
Last Post: amindfv
Sad LTE data does not work on T-Mobile US with latest postmarketOS 21.06 SP3 PacificSinewave 1 2,064 11-07-2021, 10:15 AM
Last Post: beta-user
  GCI data on Pine Phone nelstomlinson 0 1,594 09-26-2021, 04:04 PM
Last Post: nelstomlinson
