RockPro64 - HDMI and higher resolutions
Hey, everyone.
I’ve been rummaging through LibreELEC’s patches and there are some awesome changes being made available.
In particular, the following patch-set by knaerzche: LibreELEC.tv/linux-1000-drm-rockchip.patch at master · LibreELEC/LibreELEC.tv · GitHub
That’s re-work from Kwiboo’s earlier patches to enable higher resolution modes with RK3328 && RK3399 SBCs through HDMI.
What the patch-set effectively does - makes changes to use the big vop along with mpll_cfg table alterations to allow the devices to output up-to UHD resolutions.
On my particular setup, it enables:
  • Use of the full WQHD resolution on my main monitor with the RockPro64 - previously stuck at FHD only
  • Correct detection and use of the QHD monitor with RP64/ Rock64 (previously neither SBCs could even detect compatible mode - monitor doesn’t work)
  • Correct detection and use of 1440x900 monitor (previously, neither SBCs could detect compatible mode - monitor doesn’t work)
Here is my kernel package setup to use the patch-set for ManjaroARM if someone wants to give it a shot:
https://github.com/psstoyanov/linux-rockchip-hdmi-fixes
Here is the RockPro64 connected to 27" QHD ElectriQ monitor using the native resolution:
https://twitter.com/PakoSStoyanov/status...26530?s=20
As a note:
- For UHD I don't have a monitor to try it out. I'm not sure if 60Hz has been enabled or not but 30Hz should work for sure
- On my WQHD monitor 60Hz seems to work fine with RP64
Device: Pinebook Pro 128GB No:246 / MainOS: Manjaro ARM
Godot and Flutter - creating something can be fun with the right tools!
RockPro64 - HDMI and higher resolutions - by PakoSt - 11-16-2021, 03:48 PM
  irradium (based on crux linux) RockPro64 riscv64, aarch64 mara 9 16,598 10-31-2025, 06:33 PM
  New OS for RockPro64 is here, TwisterOS Armbian jtremblant 92 136,819 08-17-2024, 02:32 PM
Last Post: taltamir
  OpenEuler OS on RockPro64 Yuriy Gavrilov 0 2,071 06-15-2024, 09:38 AM
Last Post: Yuriy Gavrilov
  yocto for RockPro64 Fide 1 3,290 01-16-2024, 10:01 AM
Last Post: Fide
  Installing Ubuntu Server on RockPro64 deutschlmao 2 6,746 10-29-2023, 04:43 PM
Last Post: brotherj4mes
  Vanilla mainline Debian 11 (Bullseye) on the RockPro64 Pete Tandy 22 32,441 08-16-2023, 01:34 AM
Last Post: varac
  slarm64 (unofficial slackware) ROCKPro64 RK3399 (aarch64) mara 54 110,563 08-11-2023, 11:13 AM
  How to enable CoreSight ETM trace on RockPro64 shpark 0 2,769 05-21-2023, 11:34 PM
Last Post: shpark
  Rockpro64 Dead on arrival? quixoticgeek 1 2,938 03-12-2023, 06:55 PM
Last Post: quixoticgeek
  RockPro64 boot questions misterc 3 4,652 01-13-2023, 06:21 PM
Last Post: misterc
