Unreliable display in Armbian and Debian
Update:
Scratch that and try directly LibreELEC's image to see it will work for you: https://libreelec.tv/downloads/rockchip/
Original:
You will see the same issue with all of them unless the patch-set from LibreELEC is in use.
The patch-set in question: https://github.com/LibreELEC/LibreELEC.t...chip.patch
I'm not as familiar with Armbian to see if the patch-set is already in use (I recall it was mentioned in their forum at one point but that was for rk3328).
You could try Manjaro with the following kernel that I've modified to see if it works for your setup: https://github.com/psstoyanov/linux-rockchip-hdmi-fixes
(dm me if you prefer already generated Manjaro package instead of building it yourself)
If it is working fine then apply the patch-set to your preferred distro.
Device: Pinebook Pro 128GB No:246 / MainOS: Manjaro ARM
Godot and Flutter - creating something can be fun with the right tools!
RE: Unreliable display in Armbian and Debian - by PakoSt - 11-17-2021, 05:42 AM
  Freezes and kernel panics with Debian trixie jssfr 4 3,118 04-15-2026, 06:48 PM
Last Post: prahal
  New OS for RockPro64 is here, TwisterOS Armbian jtremblant 92 169,483 08-17-2024, 02:32 PM
Last Post: taltamir
  Vanilla mainline Debian 11 (Bullseye) on the RockPro64 Pete Tandy 22 41,258 08-16-2023, 01:34 AM
Last Post: varac
  How do I enable Pine touchdisplay as display on Debian? Thisone 0 2,818 04-23-2023, 11:02 PM
Last Post: Thisone
  Is some u-boot required on the SPI for installing debian with the official installer? callegar 1 3,805 10-25-2022, 10:07 AM
Last Post: ratzzupaltuff
  Armbian images available Luke 60 140,072 08-04-2022, 06:56 AM
Last Post: Rocklobster
  Expose /dev/mali0 in armbian pedromiguel.sanchez 2 6,869 07-25-2022, 04:52 AM
Last Post: pedromiguel.sanchez
  Enable DSI/TD Ports on Armbian (jammy) dkebler 0 2,430 06-16-2022, 06:56 PM
Last Post: dkebler
  Armbian Jammy-Running fairly stable Rocklobster 0 2,684 05-04-2022, 01:00 PM
  Armbian is looking for maintainer for ROCKPro64 TRS-80 20 30,127 03-19-2022, 09:32 PM
Last Post: paralin1
