rsyslog a bad idea? Problems with ssh, openssh-server, fail2ban
(11-11-2021, 05:59 PM)mob Wrote: If I understand your set up well you need to connect your PP to your computer at home on a private network, likely behind your modem firewall. fail2ban is typically installed on servers reachable through a public ip 24/24 like webservers storing commercial information. So the risks are lower in your setting to be subject of brute force attacks. Doesn't mean you shouldn't be concerned about security, but your thread model is different from webservers.
If you have a router firewall + on your machines (useful if your devices are mobile), are using your sshd occasionally when your machine is on, using basic hardening (prevent root login, use key authentification + password), limit login to the private ip of the second device, apply security updates regularly, then the risks are low.
Since f2b is installed, if you have disk space it doesn't hurt to keep it.
If you are interested in system hardening you can have a look at lynis (check cysofy on github). But use workstation parameters, if I understand your setting, server mode would be a bit too much.
Thank you for this!
I do indeed only have a very basic understanding of networks and security and was not sure which access third parties might have to my phone when I use it at home via the router or ouside via the cellular network.
Lynis turned out to be a great tool and surprisingly user friendly -- I will have to spend more time on it.
What I have done so far is to
  -switch to key authentification from my Laptop
  -add the line ALL: ALL in the file etc/hosts.deny and ALL: <IP.ADDR.OF.MY.LAPTOP> in etc/hosts.allow (to exclude other clients)
  -change "LLMNR=yes" to "no" in /etc/systemd/resolved.conf (to close port 5355 which for some reason is open by default)
  -change the following entries in etc/ssh/sshd_config like so:
       Port 55673 (or some other unusual port number instead of the standard 22)
       AddressFamily inet (to exclude IPv6 adresses)
       PermitRootLogin prohibit-password (to prevent root logins)
       PasswordAuthentication no (to prevent logins without the key on my laptop)
       UsePAM no (because some Linux book told me to)
-install the uncomplicated firewall ufw and deny access from all machines except my laptop via "sudo ufw allow from <IP.ADDR.OF.MY.LAPTOP>"
RE: rsyslog a bad idea? Problems with ssh, openssh-server, fail2ban - by Anna - 11-12-2021, 12:32 AM
  ssh server unreachable lesteretsel 2 2,272 12-19-2024, 02:44 PM
Last Post: lesteretsel
  PureMaps and OSM Scout Server maps download biketool 7 7,264 10-04-2024, 04:25 AM
Last Post: vusra
  Stability problems with 6.1 kernel Zebulon Walton 9 6,985 05-12-2023, 08:09 AM
Last Post: zetabeta
  DNS Problems with Mobile Data arno_nuehm 29 30,310 10-29-2022, 09:16 AM
Last Post: treebeard
  Problems after Tow-Boot Dinosaur1946 3 3,681 09-18-2022, 12:48 AM
Last Post: SpaggettiCoder
  Will this battery-saving script cause problems? rp3 1 2,598 08-28-2022, 02:00 PM
  Tow-boot problems and restoring uboot Zebulon Walton 15 15,160 08-14-2022, 11:09 AM
Last Post: shulamy
  How to enable SSH server? jnpine 16 26,704 04-02-2022, 11:10 AM
Last Post: RTP
  Browser cog - Problems on Mobian arno_nuehm 5 7,194 02-10-2022, 03:27 PM
Last Post: pothos
  ARM Microsoft Teams-problems installing eaglebeckley 15 22,393 01-14-2022, 01:59 AM
Last Post: Tazdevl
