cryptocurrency on mobian/pinephone
#28
(02-04-2022, 09:11 AM)beta-user Wrote:
(02-04-2022, 07:10 AM)biketool Wrote: Amazon and Ebay were both supposed to start accepting BTC this year
That's pretty cool! But doesn't bitcoin have huge transaction fees?
Not really as far as I know, maybe a few cents or less I think, I have never sent or received bitcoin except as a way to arbitrage other 'coins' but it was never noticeable, not sure if BTC has options for urgency of transfer with different rates like XMR has(I have only ever used the cheap option).
I think there are coins which have 'gas fees' which I think might go to devs, miners, node operators, or stakers; not sure, I think etherium among those with outrageous 'gas fees' decided by the developer and operators but there are only a few useful coins in my opinion and I would not use one which did that.
I think XMR-Monero is among the most cyberpunk of all, a good established code base, privacy by design, easy seed words wallet recovery, variable priority pricing for transfer speed, and was designed to fix the perceived problems with bitcoin.  Bitcoin is useful because it is the most accepted coin, is easy to buy and sell, you can open all of the private one-shot throw-away wallets you like for transferring easy to buy BTC to your favorite coin, and while I mostly dislike an open ledger blockchain with NO privacy it is useful for proving ownership of your wallet for collateral purposes.  Atomic swap will make hopping between 'coins' easier and is now in beta testing.
cryptocurrency on mobian/pinephone - by biketool - 11-01-2021, 01:19 PM
RE: cryptocurrency on mobian/pinephone - by ryo - 11-02-2021, 08:27 AM
RE: cryptocurrency on mobian/pinephone - by ryo - 11-02-2021, 09:43 PM
RE: cryptocurrency on mobian/pinephone - by ryo - 11-04-2021, 01:59 AM
RE: cryptocurrency on mobian/pinephone - by ryo - 11-05-2021, 08:05 AM
RE: cryptocurrency on mobian/pinephone - by biketool - 02-06-2022, 07:48 AM
  bookworm vs trixie discussion for mobian in pinephone regular. zetabeta 77 41,440 10-27-2025, 10:19 AM
  Mobian MMS/SMS text problem bcnaz 16 26,735 09-15-2025, 02:42 AM
Last Post: georgegohl888
  XLibre for Mobian Hiraghm 1 2,128 06-30-2025, 01:38 AM
Last Post: Haroldkent
  Axolotl on PinePhone / Mobian arno_nuehm 223 272,287 06-25-2025, 01:19 PM
Last Post: anonymous
  VoIP account on mobian dialer j_s 0 1,902 06-15-2025, 04:19 PM
Last Post: j_s
  Mobian Pinephone Notification LED biketool 2 2,436 06-07-2025, 03:19 PM
  Vivaldi Web browser nearly native for Mobian biketool 3 2,852 05-06-2025, 02:19 AM
  mobian calamares fail merom 2 2,844 04-29-2025, 02:10 PM
Last Post: mdk
  Pinephone seems tobe using 4G data instead of Wifi data grump_fiddle_reinstall 7 4,934 02-20-2025, 02:47 PM
Last Post: puffchumpy
  mobian phosh on screen keyboard not popping up for Chromium/Electron apps grump_fiddle_reinstall 1 2,953 01-15-2025, 08:08 PM
