UART switch not working [EDIT: I got it working]
(10-24-2021, 10:40 PM)KC9UDX Wrote: You should still have sound from the main speakers, just not from the headphone jack.  Where did you get the cable?  There are cables that are wrong and Pine64 even used to sell them.  The correct one is 3.3V, the wrong one is 5V.  It might be possible a wrong cable has RX and TX swapped, too.
Make sure your terminal is set for 1.500.000 baud.  I know the first time I did it, I misread it as 150.000 baud.
I made a cable from old headphones and a Tigard tool switched to 3.3V, and I double checked the values with a meter. I think I had 1.5M baud set correctly, but I'll try again tomorrow.
Thanks for the clarification about the sound behavior, that wasn't obvious from what I had read!
RE: UART switch not working - by KC9UDX - 10-24-2021, 06:45 PM
RE: UART switch not working - by kileel - 10-24-2021, 08:45 PM
RE: UART switch not working - by KC9UDX - 10-24-2021, 10:40 PM
RE: UART switch not working - by kileel - 10-24-2021, 10:56 PM
RE: UART switch not working - by KC9UDX - 10-24-2021, 11:17 PM
  New Working nVME gilwood 1 3,903 11-17-2024, 04:24 AM
Last Post: reukiodo
  Explaination for UART through-hole pads? wishindo 3 4,535 04-13-2023, 07:11 AM
  keyboard and usb ports not working User 24565 3 6,510 02-15-2022, 10:12 AM
  pinebook pro trackpad randomly stops working chewie 5 10,437 08-10-2021, 04:33 PM
Last Post: chewie
  Some Keys No Longer Working pietenpol 0 3,282 06-05-2021, 05:39 PM
Last Post: pietenpol
Question External Monitor not Working sciolus 5 10,363 05-05-2021, 02:05 AM
Last Post: aurora.borealis
  Some keyboard keys not working oddsocks 10 19,911 04-20-2021, 08:33 AM
Last Post: dsimic
  Microphone not working on Pinebook Pro vfr400racer 2 7,107 03-21-2021, 02:56 AM
Last Post: vfr400racer
  Anyone have a microphone working on a Pinebook Pro? Rachel Stone 5 9,097 02-20-2021, 05:21 AM
Last Post: dsimic
  Brand-new Pinebook Pro - keyboard not working guy100 8 17,031 10-09-2020, 10:49 AM
Last Post: guy100
