Installed Apps not opening
One thing I've noticed is a lot of apps that do that behavior are not actually compatible with the pinephone yet. For almost every app I troubleshot that did that, they were actually crashing or stalling on start, and launching from a terminal would would only tell me where they got hung up.
It's a little frustrating that you can install whatever you want with no way to know if its broken, but all you can really do is try contacting the developer of the app to file a bug report.
Installed Apps not opening - by mmd604 - 10-06-2021, 08:27 PM
RE: Installed Apps not opening - by dukla2000 - 10-07-2021, 09:43 AM
RE: Installed Apps not opening - by gamerminstrel - 10-07-2021, 09:55 AM
RE: Installed Apps not opening - by ragreenburg - 10-08-2021, 08:15 AM
RE: Installed Apps not opening - by gamerminstrel - 10-08-2021, 09:16 AM
RE: Installed Apps not opening - by ragreenburg - 10-08-2021, 09:29 AM
  mobian phosh on screen keyboard not popping up for Chromium/Electron apps grump_fiddle_reinstall 1 865 01-15-2025, 08:08 PM
  Keyboard not popping up on QT apps 3x5co 1 1,676 02-08-2024, 11:45 PM
  mobian installed to eMMC - how to install tow-boot grump_fiddle_reinstall 6 6,090 11-22-2023, 11:46 AM
Last Post: aLoop100o
  How to check if tow-boot is installed? jojuma 3 2,737 09-29-2023, 11:29 PM
  Why is Firefox ESR not listet under "Installed" in "Software" jojuma 0 1,198 08-30-2023, 03:23 PM
Last Post: jojuma
  PSA: anacron might be disabled if 2.3-33 was ever installed treebeard 0 1,271 11-21-2022, 02:32 PM
Last Post: treebeard
  Giving certain audio apps priority on the lock screen and pulldown 3x5co 0 1,500 07-17-2022, 10:34 AM
Last Post: 3x5co
  Using lat/lon in GPS/GNSS apps and Messaging biketool 6 5,664 05-04-2022, 11:45 AM
Last Post: wibble
  Error - megapixels not opening user641 17 15,796 03-29-2022, 03:43 PM
Last Post: bcnaz
  Apps and SD Card biketool 2 3,012 03-06-2022, 09:47 AM
