eMMC disconnecting for no reason?
I put this into the general discussion section because it seems to be a problem with my hardware, not just Linux.
My Pinebook Pro seems to have a strange issue that I couldn't google. This post is pretty much a better version of my older post with more details about the problem. I could not solve the problem since creating that post, and I finally found some time to look more into it and ask more questions on this forum.
So my problem is that when I shake my laptop, close the bottom lid, or sometimes don't do anything remotely destructive at all, the eMMC gets disconnected from the board in a very weird way. Reinserting the eMMC does solve the problem, but not permanently. What's really strange about the way it gets disconnected is that the U-boot partition still gets recognized by the firmware, and it can even start booting up a kernel, but then the initramfs fails to locate the root partition and the booting process stops. The eMMC can also get disconnected while the system is running, which causes a lot of I/O errors and a complete breakdown of the running system (basically what happens when you unmount root). The only distros that I've tried are Manjaro ARM (XFCE) and elementary OS. Should I try other distros? Is it a problem with my eMMC? Maybe the main board? Should I hold the eMMC harder in place? Am I doing something wrong? Please help me.
eMMC disconnecting for no reason? - by overlisted - 10-05-2021, 06:55 PM
  Happy eMMC and SDcard OS usage for Pinebook Pro Newbies... Paulie420 42 59,117 11-20-2023, 06:22 PM
  I'm booting from NVME but I want to switch back to eMMC acruhl 4 1,384 04-23-2023, 06:58 AM
Last Post: acruhl
  Doesn’t power on after flashing emmc badguru 3 1,138 02-25-2023, 09:00 PM
Last Post: badguru
  eMMC problem with Tow-Boot/u-boot on SPI repa 3 1,615 02-21-2023, 01:49 AM
Last Post: repa
  Partial boot after installing Manjaro on emmc regivanx 11 2,956 02-06-2023, 09:11 AM
  Unable to Boot anything (emmc or SDcard) line72 5 1,895 01-17-2023, 12:07 PM
Last Post: nfms
  What OS have you recently flashed onto PBP eMMC? jcun4128 6 2,245 11-26-2022, 09:39 AM
  Unable to boot from emmc after flashing it rfm83 3 1,680 11-08-2022, 10:59 PM
Last Post: rfm83
  Pinebook picky about which EMMC will boot flatulent_piney 8 2,884 11-05-2022, 06:03 PM
Last Post: ajtravis
  After Flashing eMMC, Will Not Boot Mossbot 5 2,227 09-28-2022, 06:22 PM
