Pinetime almost dead... only shows Infinitime logo.
This sounds like something @JF002 could comment on - but also you could raise a ticket on GitHub: https://github.com/InfiniTimeOrg/InfiniTime/issues
If you are able to open the watch, probably the best option would be to fresh-flash it. (This may end up being your only option anyway.)
In terms of the steps you performed, I am guessing you were on a (manually) validated (+) version of 1.2, then flashed 1.3 via GadgetBridge? Did you then validate the firmware?
You say you are unable to connect - do you mean that is is stuck on the boot screen?
Generally my process for upgrading is as follows:
1. Start from a validated firmware that works. As it takes a while, I like to charge the watch at the same time.
2. Download DFU from releases page and upload via GadgetBridge.
3. The PineTime resets itself as part of the upgrade. I then test basic functionality, such as the ability to connect to my phone via BT.
4. Once I am happy it is able to perform in at least some basic manner, I go into the menu and validate it.
Is your process different from this?
(+) By validated, I mean you went into the menu after flashing the DFU file and pressed a button to validate the firmware.
RE: Pinetime almost dead... only shows Infinitime logo. - by barray - 10-03-2021, 05:04 PM
  Open-Source Support for PineTime LTE (eSIM) emilyjohnson63 2 2,231 11-01-2025, 05:55 PM
Last Post: euiccc2025
  Migrating to PineTime from a Fitbit dhdurgee 0 2,928 09-25-2025, 12:41 PM
Last Post: dhdurgee
  Brand new sealed Pinetime boot loop elver 0 9,918 09-10-2025, 06:41 AM
Last Post: elver
  Pinetime Black Screen philipallmon 1 4,371 07-30-2025, 11:44 PM
Last Post: karthick
  ? Introducing RoutineHero: A PineTime Smartwatch for Kids' Routines + Companion App oscar-gardiazabal 2 1,316 07-29-2025, 04:49 AM
Last Post: oscar-gardiazabal
  PineTime charging issues - connecting pins black gsoundsgood 2 2,495 09-15-2024, 02:59 PM
Last Post: gsoundsgood
  How do I clear all personal data from the pinetime smartwatch? taltamir 6 3,911 08-22-2024, 10:34 AM
Last Post: taltamir
  [SOLVED] Gadgetbridge not pairing with pinetime zoof 3 7,902 06-25-2024, 12:21 AM
Last Post: Amen
  PineTime at FOSDEM jmlich 5 4,737 02-07-2024, 11:48 PM
  PineTime turns off when removed from cradle tynstar 0 1,738 01-31-2024, 11:57 AM
Last Post: tynstar
