RKDevTool
I have been playing with RKDevTool v2.71 on the Quartz64 running Android and it appears to work.
I haven't yet tried to write an image to eMMC with it.  Doing this requires knowledge that I don't yet have.
I found that versions 4.x of Rockchip Driverassistant wouldn't work, but 5.1.1 does. Well either that or I made a mistake somewhere.
To run RKDevTool one needs to plug in a Windows laptop with an A to A USB cable, shut down the Quartz64, press the "recovery" button and whilst continuing to press it power on the Quartz64.
This will put the Quartz64 into "loader" mode.
In RKDevTool in Advanced Functions you can reset the Quartz64 (boot Android again) or go into Maskrom mode.
The ExportImage feature only works if Start + Count doesn't exceed 65536 and with Start=0 and Count=65536 it appears to dump out the first 32MB of the eMMC module.
I haven't played with the batch tool yet.
I don't suppose that these tools are that important with a Quartz64 unless you want to seal it up in a box making removal of the eMMC module difficult, but my objective is to learn more generally about the RK3566 at the moment.
I hope that this is useful to someone as it took me hours to figure it out.
RKDevTool - by dieselnutjob - 10-01-2021, 03:02 PM
RE: RKDevTool - by dieselnutjob - 10-12-2021, 12:50 PM
RE: RKDevTool - by dieselnutjob - 10-13-2021, 07:06 AM
RE: RKDevTool - by dieselnutjob - 10-24-2021, 06:13 AM
