Phosh: Idles to Lockscreen Without Powering Off Display
I have my Pinephone with Arch+Phosh installed set to turn off the display after one minute, the problem is that instead of turning off the display it will switch to the lock screen and stay powered on indefinitely. This is remedied when I restart Phosh with
# systemctl restart phosh.service
then it will behave as expected and power off the screen after one minute and the problem is gone until I reboot.
I've re-installed Arch+Phosh but the problem persists. It's a custom build so it could be one of a hundred things causing this to happen.
I looked to see if anyone else was having this problem but I couldn't find anything about it. I played around with the phosh.service file thinking  the problem had something to do with the order Phosh is started but I haven't gotten anything to work. Anyone have this problem?
Edit: I solved the problem, it was caused by
/usr/bin/gjs /usr/share/gnome-shell/org.gnome.ScreenSaver
running at boot causing conflict with the screen turning off. I renamed org.gnome.ScreenSaver to org.gnome.ScreenSaver.bak effectively disabling it and the problem went away.
Phosh: Idles to Lockscreen Without Powering Off Display - by Merc - 10-01-2021, 06:35 AM
  [Video] PinePhone Touchscreen on NuttX: MIPI DSI, Display Engine, Touch Panel lupyuen 2 3,044 09-29-2023, 11:37 PM
Last Post: lupyuen
Photo Mobian with X11 without Wayland and Phosh. Manieck71 0 2,371 09-09-2023, 07:35 AM
Last Post: Manieck71
  How to disable lock screen in Phosh? lat 14 21,751 03-31-2023, 04:17 AM
Last Post: Eugo
  Article: NuttX RTOS for PinePhone: Display Engine lupyuen 0 2,123 12-22-2022, 06:01 PM
Last Post: lupyuen
  Article: NuttX RTOS for PinePhone: MIPI Display Serial Interface lupyuen 0 1,950 12-14-2022, 05:49 PM
Last Post: lupyuen
  Fedora + Phosh for PinePhone njha 74 195,510 12-12-2022, 10:19 PM
Last Post: wcdeich4@hotmail.com
  Article: Rendering PinePhone's Display (DE and TCON0) lupyuen 0 2,043 10-29-2022, 06:09 PM
Last Post: lupyuen
  Article: NuttX RTOS for PinePhone: Display Driver in Zig lupyuen 0 1,989 10-17-2022, 07:02 PM
Last Post: lupyuen
  Article: Understanding PinePhone's Display (MIPI DSI) lupyuen 2 3,472 10-01-2022, 05:52 PM
Last Post: lupyuen
  Enable 'upcoming-events' on Mobian/Phosh Korac 3 4,684 09-14-2022, 01:19 AM
Last Post: dukla2000
