Vanilla mainline Debian 11 (Bullseye) on the RockPro64
(09-26-2021, 04:02 AM)t4_4t Wrote: > The problem was caused by the "HDMI to VGA adapter",
> and connecting it directly to the monitor solved your second report.
> Then just like my case, you also encountered Error: "'grub-install dummy' failed".
> I interpreted your report as such, is that correct ?
> If so, you should be able to boot from the SD-Card with the same solution as I did.
> But, the conditions are as follows
> If the above meets your requirements, I can describe how I did it.
Yes, the error I'm getting is "grub-install dummy failed," and at the exact point which you described.
I was looking at some potential solutions, like the one at https://wiki.debian.org/GrubEFIReinstall
but when I got to step 2 there were some immediate problems:
I tried passiing the kernel parameter "efi=runtime" by pressing the 'e' key with Graphical Rescue selected, then adding that parameter to the line beginning with 'linux.' I then booted (Ctrl-X) into rescue mode, but the directory /sys/firmware/efi/efivars remains empty, and any attempt to mount it results in failure, just as it did when automatically selecting the default rescue mode parameters.
I'm very interested in learning your method of getting Debain to boot off the microSD.
> In the manual partitioning you mention, there are an infinite number of combinations.
> Naturally, it is impossible to try every partition.
> Therefore, I have only tried the following standard partitioning that seems to be recommended.
My partitioni scheme is heavily cutomized but I don't think it'll be an issue in this case, as all directories mentioned in the tutorial are contained on the root (/)  parititon (/, swap, /home, /srv, /tmp and /var are their own separate primary partitions). There is also an EFI partition that I created first during setup.
I'm definitely willing to give your way a try with this setup.
Thanks again for your detailed instructions. esterday I didn't even think I'd get this far.
RE: Vanilla mainline Debian 11 (Bullseye) on the RockPro64 - by Pete Tandy - 09-26-2021, 07:42 AM
  irradium (based on crux linux) RockPro64 riscv64, aarch64 mara 9 16,598 10-31-2025, 06:33 PM
  New OS for RockPro64 is here, TwisterOS Armbian jtremblant 92 136,819 08-17-2024, 02:32 PM
Last Post: taltamir
  OpenEuler OS on RockPro64 Yuriy Gavrilov 0 2,071 06-15-2024, 09:38 AM
Last Post: Yuriy Gavrilov
  yocto for RockPro64 Fide 1 3,291 01-16-2024, 10:01 AM
Last Post: Fide
  Installing Ubuntu Server on RockPro64 deutschlmao 2 6,746 10-29-2023, 04:43 PM
Last Post: brotherj4mes
  slarm64 (unofficial slackware) ROCKPro64 RK3399 (aarch64) mara 54 110,581 08-11-2023, 11:13 AM
  How to enable CoreSight ETM trace on RockPro64 shpark 0 2,769 05-21-2023, 11:34 PM
Last Post: shpark
  How do I enable Pine touchdisplay as display on Debian? Thisone 0 2,163 04-23-2023, 11:02 PM
Last Post: Thisone
  Rockpro64 Dead on arrival? quixoticgeek 1 2,938 03-12-2023, 06:55 PM
Last Post: quixoticgeek
  RockPro64 boot questions misterc 3 4,652 01-13-2023, 06:21 PM
Last Post: misterc
