Vanilla mainline Debian 11 (Bullseye) on the RockPro64
> The problem was caused by the "HDMI to VGA adapter",
> and connecting it directly to the monitor solved your second report.
> Then just like my case, you also encountered Error: "'grub-install dummy' failed".
I interpreted your report as such, is that correct ?
If so, you should be able to boot from the SD-Card with the same solution as I did.
But, the conditions are as follows
If the above meets your requirements, I can describe how I did it.
In the manual partitioning you mention, there are an infinite number of combinations.
Naturally, it is impossible to try every partition.
Therefore, I have only tried the following standard partitioning that seems to be recommended.
Partitioning method:
--  Guided - use entire disk
Select disk to partition:
--  MMC/SD card #1 (mmcblk?) - 15.9 GB SD SC16G
Partitioning scheme:
--  All files in one partition (recommended for new users)
RE: Vanilla mainline Debian 11 (Bullseye) on the RockPro64 - by t4_4t - 09-26-2021, 04:02 AM
  irradium (based on crux linux) RockPro64 riscv64, aarch64 mara 9 16,598 10-31-2025, 06:33 PM
  New OS for RockPro64 is here, TwisterOS Armbian jtremblant 92 136,819 08-17-2024, 02:32 PM
Last Post: taltamir
  OpenEuler OS on RockPro64 Yuriy Gavrilov 0 2,071 06-15-2024, 09:38 AM
Last Post: Yuriy Gavrilov
  yocto for RockPro64 Fide 1 3,291 01-16-2024, 10:01 AM
Last Post: Fide
  Installing Ubuntu Server on RockPro64 deutschlmao 2 6,746 10-29-2023, 04:43 PM
Last Post: brotherj4mes
  slarm64 (unofficial slackware) ROCKPro64 RK3399 (aarch64) mara 54 110,581 08-11-2023, 11:13 AM
  How to enable CoreSight ETM trace on RockPro64 shpark 0 2,769 05-21-2023, 11:34 PM
Last Post: shpark
  How do I enable Pine touchdisplay as display on Debian? Thisone 0 2,163 04-23-2023, 11:02 PM
Last Post: Thisone
  Rockpro64 Dead on arrival? quixoticgeek 1 2,938 03-12-2023, 06:55 PM
Last Post: quixoticgeek
  RockPro64 boot questions misterc 3 4,652 01-13-2023, 06:21 PM
Last Post: misterc
