Chatty, SMS does not work - could hardware be at fault?
#33
(10-25-2021, 08:44 AM)kqlnut Wrote: You can find the instructions to revert to the stock firmware here in biktorgj's repo.
Edit: You can also try switching out just the ADSP firmware as mentioned here. You are probably on 01.003, stock is 01.002. That's the closed source part which I think is more likely to be responsible for problems than the open source part of the custom firmware.
GREAT!
Thank you!
(10-25-2021, 09:45 AM)arno_nuehm Wrote: Could you try to change your Mobile Network Settings to "2G only"? After a modem restart / phone restart, I am usually able to send SMS via Chatty - but only that way (O2Germany Sim Card).
Yes, that works. I am with O2 Germany, too.
But since I followed the steps described here I am permanently able to send messages.
RE: Chatty, SMS does not work - could hardware be at fault? - by AntonReiser - 10-25-2021, 11:21 AM
  Alarm clock doesn’t work Captain1ndustry 13 23,819 12-15-2024, 07:07 PM
Last Post: baptx
  Chatty Matrix Decryption Key jojuma 2 2,450 02-26-2024, 12:48 PM
  Jabber with chatty user641 2 2,929 11-12-2023, 02:10 AM
Last Post: user641
  gnome-control-center: segmentation fault on startup jojuma 4 4,065 09-12-2023, 08:49 AM
Last Post: jojuma
  wwan0 (SIM interface) doesn't work with OpenVPN nickolas 6 5,540 09-05-2023, 11:16 AM
Last Post: nickolas
  Chatty does not work after suspend mode user641 4 5,029 07-18-2023, 10:43 AM
Last Post: alaraajavamma
  reset wifi hardware/driver when it dies through console on pp? tuxcall 4 4,409 07-18-2023, 08:54 AM
Last Post: junelung
  Wifi doesn't work after update nickolas 2 3,350 04-14-2023, 10:07 AM
Last Post: nickolas
  Most recent Mobian image or installer image known to work? DrPlamsa 13 11,982 02-26-2023, 11:47 PM
Last Post: SukiiPooru
  beware chatty 0.7.0~rc0-1 treebeard 6 5,960 11-06-2022, 04:51 PM
Last Post: treebeard
