Chatty, SMS does not work - could hardware be at fault?
(09-19-2021, 12:27 PM)kqlnut Wrote: Before you do flashing experiments, you could try more distros. I would at least give Manjaro Phosh a try and see how it goes, they are pretty up to date on stuff. Some people have reported problems with sending SMS and could get it to work by switching go 2G only in the settings before sending. Maybe that works for you too. If nothing works, I would open an issue on the bug tracker of the distro of your choice and hope someone with more technical knowledge can help you out on there.I highly doubt this is a hardware problem if the modem is otherwise functional.
If you do decide to flash the alternative firmware at some point (which by the way is also safer than the stock firmware as sudden power loss can't corrupt the modem), you can also revert back to the stock firmware later.
That's very valuable info again. I'll assume then that the hardware is OK and hope to fix the issue at some point. So I finally get to keep a 3GB Pinephone!
I noticed that I do not receive all SMS messages, people told me that they got error messages when trying to write to me. It mostly seems to work but not always.
Setting "2G only" and trying Manjaro (the version on the multi distro image and a new version installed on another SD card) unfortunately has not worked, I still could not send messages.
However, Manjaro shows the error message "Network Management:Modem (quectelqmi_0) The modem shows no carrier" immediately after booting it. Could that be a hint what the problem might be?
If not I guess the next step would be to install the alternative firmware.
RE: Chatty, SMS does not work - could hardware be at fault? - by AntonReiser - 09-19-2021, 01:46 PM
  Chatty Matrix Decryption Key jojuma 2 278 02-26-2024, 12:48 PM
  Jabber with chatty user641 2 982 11-12-2023, 02:10 AM
Last Post: user641
  gnome-control-center: segmentation fault on startup jojuma 4 1,101 09-12-2023, 08:49 AM
Last Post: jojuma
  wwan0 (SIM interface) doesn't work with OpenVPN nickolas 6 2,148 09-05-2023, 11:16 AM
Last Post: nickolas
  Chatty does not work after suspend mode user641 4 1,948 07-18-2023, 10:43 AM
Last Post: alaraajavamma
  reset wifi hardware/driver when it dies through console on pp? tuxcall 4 1,903 07-18-2023, 08:54 AM
Last Post: junelung
  Wifi doesn't work after update nickolas 2 1,243 04-14-2023, 10:07 AM
Last Post: nickolas
  Most recent Mobian image or installer image known to work? DrPlamsa 13 4,992 02-26-2023, 11:47 PM
Last Post: SukiiPooru
  beware chatty 0.7.0~rc0-1 treebeard 6 2,621 11-06-2022, 04:51 PM
Last Post: treebeard
Exclamation The webcam doesn't work in Firefox anonymous 0 741 11-06-2022, 01:45 PM
Last Post: anonymous
