Chatty, SMS does not work - could hardware be at fault?
(09-19-2021, 11:53 AM)AntonReiser Wrote: What to do? Leave it as it is because that is already the optimum and search for another cause? Reinstall the new firmware because you never know? Or install the OLD firmware (if it's available) since it works on the other phone?
Before you do flashing experiments, you could try more distros. I would at least give Manjaro Phosh a try and see how it goes, they are pretty up to date on stuff. Some people have reported problems with sending SMS and could get it to work by switching go 2G only in the settings before sending. Maybe that works for you too. If nothing works, I would open an issue on the bug tracker of the distro of your choice and hope someone with more technical knowledge can help you out on there.I highly doubt this is a hardware problem if the modem is otherwise functional.
If you do decide to flash the alternative firmware at some point (which by the way is also safer than the stock firmware as sudden power loss can't corrupt the modem), you can also revert back to the stock firmware later.
RE: Chatty, SMS does not work - could hardware be at fault? - by kqlnut - 09-19-2021, 12:27 PM
  Alarm clock doesn’t work Captain1ndustry 13 23,743 12-15-2024, 07:07 PM
Last Post: baptx
  Chatty Matrix Decryption Key jojuma 2 2,441 02-26-2024, 12:48 PM
  Jabber with chatty user641 2 2,919 11-12-2023, 02:10 AM
Last Post: user641
  gnome-control-center: segmentation fault on startup jojuma 4 4,047 09-12-2023, 08:49 AM
Last Post: jojuma
  wwan0 (SIM interface) doesn't work with OpenVPN nickolas 6 5,514 09-05-2023, 11:16 AM
Last Post: nickolas
  Chatty does not work after suspend mode user641 4 5,014 07-18-2023, 10:43 AM
Last Post: alaraajavamma
  reset wifi hardware/driver when it dies through console on pp? tuxcall 4 4,397 07-18-2023, 08:54 AM
Last Post: junelung
  Wifi doesn't work after update nickolas 2 3,343 04-14-2023, 10:07 AM
Last Post: nickolas
  Most recent Mobian image or installer image known to work? DrPlamsa 13 11,913 02-26-2023, 11:47 PM
Last Post: SukiiPooru
  beware chatty 0.7.0~rc0-1 treebeard 6 5,937 11-06-2022, 04:51 PM
Last Post: treebeard
