Burning images on Mac (OSX) the easy way
(06-23-2016, 09:15 PM)Bluphire Wrote:
(06-23-2016, 11:44 AM)killorfb Wrote: Just so you know, I used SD Formatter (https://www.sdcard.org/downloads/formatter_4/index.html) from the SD Card association to format my card. Thanks Luke!
trying to flash 64gb rooted android LCD to a 64gb sd card. i get a warning after clicking of "Restore Backup" saying the image size is larger than the storage size. the difference is 1,978,662,912 bytes... "android-rooted-ver5.1.1-lcd-version-20160603-pine64-64GB" is 679.2mb. what is wrong? please help, i want to use my battery and LCD.
Matt
It sounds like the capacity of your microSD is slightly smaller than the 64GB image you are trying to burn. Slight variations in storage capacity do occur between card brands. This issue is being worked on.
Best thing for now, just to test things out, is to try burning the available 32GB image to your 64GB card instead.
RE: Burning images on Mac (OSX) the easy way - by Ghost - 06-24-2016, 01:46 AM
  Invalid package error in Manjaro-ARM? Easy fix 98cwitr 0 2,259 05-23-2022, 08:49 AM
Last Post: 98cwitr
  why are there different images based on sd card size? checktravis 2 6,001 07-28-2016, 08:41 AM
Last Post: xalius
Exclamation Images too large? kikootwo 9 20,049 07-19-2016, 03:23 PM
Last Post: jimwrey
