*urgent help*calls and gnome-conatcs gone after update
(09-13-2021, 04:35 AM)goku499 Wrote: I'm usually doing updates from ssh so I can clearly see what happens. I noticed 2 packets were held back (gnome-maps and common-folks). When I wanted to force install them, apt told me it would uninstall A LOT of important packets so I skipped it.
Not sure how or why you had it bypassed by using the GUI. I mean, it should be safer from GUI...
In this instance, it would not 'just update' ... but showing "missing dependencies".
I found the missing chats, calls, contacts Apps  in 'the Software Store' and simply installed them from there.
I did not see any mention of 'Maps' in the missing dependencies...
This description is for my 'updating' my daily driver phone.
My experience was slightly different with installing the fresh image on one of my test phones, but similar.
      LINUX = CHOICES
         **BCnAZ**
               Idea
   Donate to $upport
your favorite OS Team
RE: *urgent help*calls and gnome-conatcs gone after updateting - by bcnaz - 09-13-2021, 05:25 AM
  gnome-control-center: segmentation fault on startup jojuma 4 1,182 09-12-2023, 08:49 AM
Last Post: jojuma
  how to update mobian over tor vusra 13 7,117 07-09-2023, 08:57 PM
Last Post: vusra
  Wifi doesn't work after update nickolas 2 1,283 04-14-2023, 10:07 AM
Last Post: nickolas
  PinePhone won't boot after software update jb2000 2 1,376 03-17-2023, 07:26 AM
Exclamation Impossible to login since the latest update anonymous 12 4,395 02-26-2023, 01:01 PM
Last Post: anonymous
  No audio on calls after updating today Zebulon Walton 10 4,482 12-12-2022, 09:55 PM
Last Post: BaronAlbatross
Exclamation The latest update of eg25-manager seems to cause frequent disconnections anonymous 12 4,487 11-28-2022, 03:30 PM
  Dist-upgrade and Chatty vs Gnome-Contacts biketool 9 4,191 09-30-2022, 08:53 PM
Last Post: treebeard
  Wifi issue since last update and held back updates goku499 11 5,482 09-21-2022, 02:39 PM
Last Post: Katsujinken
  [SOLVED] Lost Internet connectivity after recent update drh 3 1,917 09-11-2022, 09:24 PM
