Anyone find a work around for the brightness issues from kernels 5.13/14?
I set up /etc/rc.local to set brightness at boot time before upgrading to the 5.13 kernel. If you do this and accidentally turn the screen off, rebooting the phone will bring the screen back. If you have ssh access you can do it from the command line.
On Mobian, rc.local is not enabled by default, you have to set up a systemd unit file for it. This is the command to run at boot or from ssh as root:
echo 400 > /sys/class/backlight/backlight/brightness
(The number "400" is an example, higher number is brighter screen. I'm actually using 600 - not sure what the max is.)
RE: Anyone find a work around for the brightness issues from kernels 5.13/14? - by Zebulon Walton - 08-31-2021, 05:41 PM
  wwan0 (SIM interface) doesn't work with OpenVPN nickolas 6 2,535 09-05-2023, 11:16 AM
Last Post: nickolas
  Chatty does not work after suspend mode user641 4 2,269 07-18-2023, 10:43 AM
Last Post: alaraajavamma
  Wifi doesn't work after update nickolas 2 1,466 04-14-2023, 10:07 AM
Last Post: nickolas
  Most recent Mobian image or installer image known to work? DrPlamsa 13 5,757 02-26-2023, 11:47 PM
Last Post: SukiiPooru
Exclamation The webcam doesn't work in Firefox anonymous 0 850 11-06-2022, 01:45 PM
Last Post: anonymous
  Modem Firmware Upgrade - Modem Busy - USB Issues biketool 10 5,519 09-23-2022, 05:15 AM
  Lot of issues after flashing mobian to emmc with tow-boot benedikt55 5 3,078 08-30-2022, 01:14 PM
Last Post: benedikt55
  Megapixels doesn't work Glenn 4 3,180 08-28-2022, 03:19 PM
Last Post: vortex
  Can't Get Nheko To Work [never mind, it's a bug] el.pollo.diablo 0 899 08-02-2022, 02:11 AM
Last Post: el.pollo.diablo
  Chatty - XMPP receiving photos - inline display doesn't work arkadione 2 2,195 07-10-2022, 03:16 AM
Last Post: arkadione
