Genode OS
#40
The clouds are lifting now. The SD-card image contains a partition table with one partition (the [1] box) featuring a file system with the boot/ directory (containing the base system image as a file). It also features the U-Boot boat loader at a certain block address. All these things are needed to boot Sculpt OS. By using the "Format" option on the entire SD-card, you replaced the entire SD-card content by a fresh formatted file system. At this point, the boot loader and the boot/ directory were gone. Sculpt still continued to run (until reboot) because was already loaded in memory, not needing the SD-card while running the base system.
In short, the "Format" operation is not what you want here. Instead, the "Expand" operation allows you to inflate the existing partition [1] to the extent of the entire SD-card. By expanding the partition (and the file system on the partition), you keep the boot loader, the partition table, and the boot/ directory in tact.
Quote:Mentioned previously it would be great to make the [1] box bigger and moved to the center or right side so it isn't in the same spot as the preset trigger on the left screen.
I have published a new image for you (version 2023-07-14) with the following changes:
  • Allowing for the use of * and # characters in phone numbers. The clear button has been moved to the current-call area to make space for the * button. Dial tones during calls are still not supported though.
  • Double tapping the power button no longer re-enters the screen saver, which should hopefully avoid confusions caused by the delay of re-enabling the display.
  • Mitigated the flickering of the panel when returning from the screen saver. Flickering can still occur right after cold boot but it normally vanishes after a minute, and the screensaver does not make it re-appear anymore.
  • Centered the storage dialog to make the partition buttons easier to hit. BTW, you can also touch on the text besides the partition number to select the partition.
Quote:If still needed, I can get a hold of a PP socket to USB chord [...]
I was actually referring to this cable: https://pine64.com/product/pinebook-pine...l-console/. When enabling the dip switch as described at https://wiki.pine64.org/index.php/PinePh...al_console you can observe log messages via a plain terminal program like picocom.
Genode OS - by steffenvongrabau - 08-29-2021, 03:29 PM
RE: Genode OS - by Zebulon Walton - 08-29-2021, 04:24 PM
RE: Genode OS - by steffenvongrabau - 08-31-2021, 06:02 AM
Genode OS - by Samurai_Crow - 08-08-2022, 09:51 PM
RE: Genode OS - by Surehand53 - 11-19-2022, 02:46 PM
RE: Genode OS - by Andidoko - 11-24-2022, 02:28 AM
RE: Genode OS - by Samurai_Crow - 11-27-2022, 06:08 PM
RE: Genode OS - by Andidoko - 12-01-2022, 01:51 AM
RE: Genode OS - by Samurai_Crow - 12-27-2022, 02:12 PM
RE: Genode OS - by wibble - 12-29-2022, 04:41 AM
Genode OS - by Samurai_Crow - 01-30-2023, 09:51 AM
RE: Genode OS - by PineFone - 02-05-2023, 10:09 AM
RE: Genode OS - by PineFone - 02-06-2023, 09:10 PM
RE: Genode OS - by Zebulon Walton - 02-07-2023, 01:13 PM
RE: Genode OS - by PineFone - 02-07-2023, 04:59 PM
RE: Genode OS - by nfeske - 02-08-2023, 05:44 AM
RE: Genode OS - by PineFone - 02-08-2023, 06:07 PM
RE: Genode OS - by nfeske - 02-10-2023, 05:02 AM
RE: Genode OS - by nfeske - 04-28-2023, 10:13 AM
RE: Genode OS - by PineFone - 04-28-2023, 03:42 PM
RE: Genode OS - by PineFone - 05-08-2023, 06:51 PM
RE: Genode OS - by Josef Söntgen - 05-09-2023, 07:08 AM
RE: Genode OS - by PineFone - 05-10-2023, 06:13 PM
RE: Genode OS - by nfeske - 05-15-2023, 08:50 AM
RE: Genode OS - by Josef Söntgen - 05-11-2023, 09:41 AM
RE: Genode OS - by PineFone - 05-11-2023, 06:41 PM
RE: Genode OS - by Josef Söntgen - 05-16-2023, 10:16 AM
RE: Genode OS - by diederik - 05-12-2023, 04:30 AM
RE: Genode OS - by Kevin Kofler - 05-12-2023, 06:01 AM
RE: Genode OS - by PineFone - 05-15-2023, 04:15 PM
RE: Genode OS - by PineFone - 05-16-2023, 07:45 PM
RE: Genode OS - by nfeske - 06-30-2023, 08:39 AM
RE: Genode OS - by PineFone - 07-05-2023, 05:59 PM
RE: Genode OS - by PineFone - 07-10-2023, 06:40 PM
RE: Genode OS - by nfeske - 07-12-2023, 05:52 AM
RE: Genode OS - by PineFone - 07-12-2023, 09:45 PM
RE: Genode OS - by nfeske - 07-13-2023, 05:03 AM
RE: Genode OS - by PineFone - 07-13-2023, 11:05 PM
RE: Genode OS - by nfeske - 07-14-2023, 10:24 AM
RE: Genode OS - by PineFone - 07-17-2023, 10:01 PM
RE: Genode OS - by PineFone - 07-18-2023, 07:02 PM
RE: Genode OS - by nfeske - 07-28-2023, 04:09 AM
RE: Genode OS - by PineFone - 08-07-2023, 06:02 PM
RE: Genode OS - by nfeske - 08-24-2023, 03:45 AM
RE: Genode OS - by PineFone - 08-30-2023, 11:45 PM
RE: Genode OS - by PineFone - 09-27-2023, 06:48 PM
RE: Genode OS - by PineFone - 06-07-2023, 03:54 PM
RE: Genode OS - by Kevin Kofler - 07-28-2023, 09:34 PM
RE: Genode OS - by PineFone - 10-17-2023, 03:44 PM
RE: Genode OS - by diederik - 10-17-2023, 04:22 PM
RE: Genode OS - by PineFone - 10-17-2023, 05:44 PM
RE: Genode OS - by Kevin Kofler - 10-17-2023, 07:04 PM
RE: Genode OS - by PineFone - 10-17-2023, 08:30 PM
RE: Genode OS - by nfeske - 10-18-2023, 05:21 AM
RE: Genode OS - by PineFone - 10-18-2023, 06:43 PM
RE: Genode OS - by nfeske - 10-19-2023, 02:29 AM
RE: Genode OS - by Kevin Kofler - 10-18-2023, 05:51 PM
RE: Genode OS - by PineFone - 10-19-2023, 03:39 PM
RE: Genode OS - by Kevin Kofler - 10-19-2023, 08:30 PM
RE: Genode OS - by PineFone - 10-23-2023, 03:47 PM
RE: Genode OS - by Kevin Kofler - 10-23-2023, 04:56 PM
RE: Genode OS - by PineFone - 10-23-2023, 05:18 PM
RE: Genode OS - by nfeske - 10-26-2023, 06:56 AM
RE: Genode OS - by PineFone - 10-30-2023, 04:34 PM
RE: Genode OS - by PineFone - 11-02-2023, 09:01 PM
RE: Genode OS - by nfeske - 11-10-2023, 09:32 AM
RE: Genode OS - by tllim - 11-11-2023, 09:35 PM
RE: Genode OS - by nfeske - 11-14-2023, 03:41 AM
RE: Genode OS - by tllim - 11-17-2023, 12:14 AM
RE: Genode OS - by Josef Söntgen - 11-23-2023, 05:47 AM
RE: Genode OS - by aLoop100o - 11-23-2023, 06:13 AM
RE: Genode OS - by moodroid - 12-28-2023, 11:29 AM
RE: Genode OS - by nfeske - 02-16-2024, 06:48 AM
RE: Genode OS - by tllim - 02-17-2024, 07:01 PM
  Genode- Sculpt OS for the PinePhone (non Linux) Surehand53 1 4,794 11-04-2023, 07:23 PM
  When should new OS's like Genode & NuttX RTOS get their own PinePhone subforum? PineFone 1 2,346 05-17-2023, 06:38 PM
Last Post: lupyuen
  ATTN MODS: Create 'Genode OS on PinePhone' Sub-Forum under PinePhone Software PineFone 3 4,698 02-11-2023, 06:23 PM
Last Post: zetabeta
  Genode OS Now Live (finally a battery friendly PP OS?) PineFone 0 2,450 02-04-2023, 09:38 AM
Last Post: PineFone
Lightbulb Article: Experiments for super low PinePhone power consumption with Genode Surehand53 1 3,655 12-27-2022, 02:21 PM
Last Post: Samurai_Crow
