Genode OS
#38
Quote:Finished the screen saver test, did some test searching with the morph browser, did NOT click "USE" under storage, opened the device menu and hit "Reboot" waiting a full minute before clicking "Confirm" and.... same problem with it wiping the SD card defaulting to the outdated Manjaro OS that came with the phone.
Given this description, I sense that you may hit a different problem, which is not related to any data corruption of the SD-card: I noticed that the U-Boot boot loader sporadically fails to detect the SD-card. In this case, U-Boot falls back to booting from eMMC. When seeing the eMMC-installed Linux booting up, I usually kill it with fire (holding the power button for 5 seconds). Once the device is powered off, cold-booting the system via another press of the power button brings up Sculpt OS - at least whenever I had observed this problem. I'm seeing this every now and then, once in about 10 boot cycles. It'd be nice of you to try cold-booting Sculpt w/o touching the SD-card the next time you see the presumed corruption. If U-Boot is indeed the problem in your case, we can at least rule out an file-system issue at the Sculpt-OS level.
Down the road, we should definitely provide a way to install Sculpt on the internal eMMC. It will boost the boot time and file-system access quite a bit. But that's for later.
BTW, do you happen to have a USB-serial cable for your PinePhone (via the audio jack) to glimpse at log messages?
Genode OS - by steffenvongrabau - 08-29-2021, 03:29 PM
RE: Genode OS - by Zebulon Walton - 08-29-2021, 04:24 PM
RE: Genode OS - by steffenvongrabau - 08-31-2021, 06:02 AM
Genode OS - by Samurai_Crow - 08-08-2022, 09:51 PM
RE: Genode OS - by Surehand53 - 11-19-2022, 02:46 PM
RE: Genode OS - by Andidoko - 11-24-2022, 02:28 AM
RE: Genode OS - by Samurai_Crow - 11-27-2022, 06:08 PM
RE: Genode OS - by Andidoko - 12-01-2022, 01:51 AM
RE: Genode OS - by Samurai_Crow - 12-27-2022, 02:12 PM
RE: Genode OS - by wibble - 12-29-2022, 04:41 AM
Genode OS - by Samurai_Crow - 01-30-2023, 09:51 AM
RE: Genode OS - by PineFone - 02-05-2023, 10:09 AM
RE: Genode OS - by PineFone - 02-06-2023, 09:10 PM
RE: Genode OS - by Zebulon Walton - 02-07-2023, 01:13 PM
RE: Genode OS - by PineFone - 02-07-2023, 04:59 PM
RE: Genode OS - by nfeske - 02-08-2023, 05:44 AM
RE: Genode OS - by PineFone - 02-08-2023, 06:07 PM
RE: Genode OS - by nfeske - 02-10-2023, 05:02 AM
RE: Genode OS - by nfeske - 04-28-2023, 10:13 AM
RE: Genode OS - by PineFone - 04-28-2023, 03:42 PM
RE: Genode OS - by PineFone - 05-08-2023, 06:51 PM
RE: Genode OS - by Josef Söntgen - 05-09-2023, 07:08 AM
RE: Genode OS - by PineFone - 05-10-2023, 06:13 PM
RE: Genode OS - by nfeske - 05-15-2023, 08:50 AM
RE: Genode OS - by Josef Söntgen - 05-11-2023, 09:41 AM
RE: Genode OS - by PineFone - 05-11-2023, 06:41 PM
RE: Genode OS - by Josef Söntgen - 05-16-2023, 10:16 AM
RE: Genode OS - by diederik - 05-12-2023, 04:30 AM
RE: Genode OS - by Kevin Kofler - 05-12-2023, 06:01 AM
RE: Genode OS - by PineFone - 05-15-2023, 04:15 PM
RE: Genode OS - by PineFone - 05-16-2023, 07:45 PM
RE: Genode OS - by nfeske - 06-30-2023, 08:39 AM
RE: Genode OS - by PineFone - 07-05-2023, 05:59 PM
RE: Genode OS - by PineFone - 07-10-2023, 06:40 PM
RE: Genode OS - by nfeske - 07-12-2023, 05:52 AM
RE: Genode OS - by PineFone - 07-12-2023, 09:45 PM
RE: Genode OS - by nfeske - 07-13-2023, 05:03 AM
RE: Genode OS - by PineFone - 07-13-2023, 11:05 PM
RE: Genode OS - by nfeske - 07-14-2023, 10:24 AM
RE: Genode OS - by PineFone - 07-17-2023, 10:01 PM
RE: Genode OS - by PineFone - 07-18-2023, 07:02 PM
RE: Genode OS - by nfeske - 07-28-2023, 04:09 AM
RE: Genode OS - by PineFone - 08-07-2023, 06:02 PM
RE: Genode OS - by nfeske - 08-24-2023, 03:45 AM
RE: Genode OS - by PineFone - 08-30-2023, 11:45 PM
RE: Genode OS - by PineFone - 09-27-2023, 06:48 PM
RE: Genode OS - by PineFone - 06-07-2023, 03:54 PM
RE: Genode OS - by Kevin Kofler - 07-28-2023, 09:34 PM
RE: Genode OS - by PineFone - 10-17-2023, 03:44 PM
RE: Genode OS - by diederik - 10-17-2023, 04:22 PM
RE: Genode OS - by PineFone - 10-17-2023, 05:44 PM
RE: Genode OS - by Kevin Kofler - 10-17-2023, 07:04 PM
RE: Genode OS - by PineFone - 10-17-2023, 08:30 PM
RE: Genode OS - by nfeske - 10-18-2023, 05:21 AM
RE: Genode OS - by PineFone - 10-18-2023, 06:43 PM
RE: Genode OS - by nfeske - 10-19-2023, 02:29 AM
RE: Genode OS - by Kevin Kofler - 10-18-2023, 05:51 PM
RE: Genode OS - by PineFone - 10-19-2023, 03:39 PM
RE: Genode OS - by Kevin Kofler - 10-19-2023, 08:30 PM
RE: Genode OS - by PineFone - 10-23-2023, 03:47 PM
RE: Genode OS - by Kevin Kofler - 10-23-2023, 04:56 PM
RE: Genode OS - by PineFone - 10-23-2023, 05:18 PM
RE: Genode OS - by nfeske - 10-26-2023, 06:56 AM
RE: Genode OS - by PineFone - 10-30-2023, 04:34 PM
RE: Genode OS - by PineFone - 11-02-2023, 09:01 PM
RE: Genode OS - by nfeske - 11-10-2023, 09:32 AM
RE: Genode OS - by tllim - 11-11-2023, 09:35 PM
RE: Genode OS - by nfeske - 11-14-2023, 03:41 AM
RE: Genode OS - by tllim - 11-17-2023, 12:14 AM
RE: Genode OS - by Josef Söntgen - 11-23-2023, 05:47 AM
RE: Genode OS - by aLoop100o - 11-23-2023, 06:13 AM
RE: Genode OS - by moodroid - 12-28-2023, 11:29 AM
RE: Genode OS - by nfeske - 02-16-2024, 06:48 AM
RE: Genode OS - by tllim - 02-17-2024, 07:01 PM
  Genode- Sculpt OS for the PinePhone (non Linux) Surehand53 1 4,794 11-04-2023, 07:23 PM
  When should new OS's like Genode & NuttX RTOS get their own PinePhone subforum? PineFone 1 2,346 05-17-2023, 06:38 PM
Last Post: lupyuen
  ATTN MODS: Create 'Genode OS on PinePhone' Sub-Forum under PinePhone Software PineFone 3 4,698 02-11-2023, 06:23 PM
Last Post: zetabeta
  Genode OS Now Live (finally a battery friendly PP OS?) PineFone 0 2,450 02-04-2023, 09:38 AM
Last Post: PineFone
Lightbulb Article: Experiments for super low PinePhone power consumption with Genode Surehand53 1 3,655 12-27-2022, 02:21 PM
Last Post: Samurai_Crow
