Genode OS
#30
(05-11-2023, 06:41 PM)PineFone Wrote: I have not encountered this issue before. Does it make difference if you un-use the Genode Partition before rebooting?
Not sure how to do that. Does it involve the terminal? Can you provide step by step instructions for testing?
If you followed Norman's guide at some point you expanded the Genode partition and made it the Default one (so that it gets used automatically when you boot the phone). In the same section there is the Use button that you can toggle to “use” or rather “un-use” the persistent file-system.
So un-using it before the reboot prevents any component from accessing the file-system during the reboot procedure. Now that should not be a problem in general and it probably will not have any effect on the issue you encountered - but its something that is simple to try out.
(The expand-step will alter the partition-table on the SD card and Sculpt will re-read it again to perform the file-system resize operation. So its interesting that the GPT appears to get corrupted during reboot.)
Genode OS - by steffenvongrabau - 08-29-2021, 03:29 PM
RE: Genode OS - by Zebulon Walton - 08-29-2021, 04:24 PM
RE: Genode OS - by steffenvongrabau - 08-31-2021, 06:02 AM
Genode OS - by Samurai_Crow - 08-08-2022, 09:51 PM
RE: Genode OS - by Surehand53 - 11-19-2022, 02:46 PM
RE: Genode OS - by Andidoko - 11-24-2022, 02:28 AM
RE: Genode OS - by Samurai_Crow - 11-27-2022, 06:08 PM
RE: Genode OS - by Andidoko - 12-01-2022, 01:51 AM
RE: Genode OS - by Samurai_Crow - 12-27-2022, 02:12 PM
RE: Genode OS - by wibble - 12-29-2022, 04:41 AM
Genode OS - by Samurai_Crow - 01-30-2023, 09:51 AM
RE: Genode OS - by PineFone - 02-05-2023, 10:09 AM
RE: Genode OS - by PineFone - 02-06-2023, 09:10 PM
RE: Genode OS - by Zebulon Walton - 02-07-2023, 01:13 PM
RE: Genode OS - by PineFone - 02-07-2023, 04:59 PM
RE: Genode OS - by nfeske - 02-08-2023, 05:44 AM
RE: Genode OS - by PineFone - 02-08-2023, 06:07 PM
RE: Genode OS - by nfeske - 02-10-2023, 05:02 AM
RE: Genode OS - by nfeske - 04-28-2023, 10:13 AM
RE: Genode OS - by PineFone - 04-28-2023, 03:42 PM
RE: Genode OS - by PineFone - 05-08-2023, 06:51 PM
RE: Genode OS - by Josef Söntgen - 05-09-2023, 07:08 AM
RE: Genode OS - by PineFone - 05-10-2023, 06:13 PM
RE: Genode OS - by nfeske - 05-15-2023, 08:50 AM
RE: Genode OS - by Josef Söntgen - 05-11-2023, 09:41 AM
RE: Genode OS - by PineFone - 05-11-2023, 06:41 PM
RE: Genode OS - by Josef Söntgen - 05-16-2023, 10:16 AM
RE: Genode OS - by diederik - 05-12-2023, 04:30 AM
RE: Genode OS - by Kevin Kofler - 05-12-2023, 06:01 AM
RE: Genode OS - by PineFone - 05-15-2023, 04:15 PM
RE: Genode OS - by PineFone - 05-16-2023, 07:45 PM
RE: Genode OS - by nfeske - 06-30-2023, 08:39 AM
RE: Genode OS - by PineFone - 07-05-2023, 05:59 PM
RE: Genode OS - by PineFone - 07-10-2023, 06:40 PM
RE: Genode OS - by nfeske - 07-12-2023, 05:52 AM
RE: Genode OS - by PineFone - 07-12-2023, 09:45 PM
RE: Genode OS - by nfeske - 07-13-2023, 05:03 AM
RE: Genode OS - by PineFone - 07-13-2023, 11:05 PM
RE: Genode OS - by nfeske - 07-14-2023, 10:24 AM
RE: Genode OS - by PineFone - 07-17-2023, 10:01 PM
RE: Genode OS - by PineFone - 07-18-2023, 07:02 PM
RE: Genode OS - by nfeske - 07-28-2023, 04:09 AM
RE: Genode OS - by PineFone - 08-07-2023, 06:02 PM
RE: Genode OS - by nfeske - 08-24-2023, 03:45 AM
RE: Genode OS - by PineFone - 08-30-2023, 11:45 PM
RE: Genode OS - by PineFone - 09-27-2023, 06:48 PM
RE: Genode OS - by PineFone - 06-07-2023, 03:54 PM
RE: Genode OS - by Kevin Kofler - 07-28-2023, 09:34 PM
RE: Genode OS - by PineFone - 10-17-2023, 03:44 PM
RE: Genode OS - by diederik - 10-17-2023, 04:22 PM
RE: Genode OS - by PineFone - 10-17-2023, 05:44 PM
RE: Genode OS - by Kevin Kofler - 10-17-2023, 07:04 PM
RE: Genode OS - by PineFone - 10-17-2023, 08:30 PM
RE: Genode OS - by nfeske - 10-18-2023, 05:21 AM
RE: Genode OS - by PineFone - 10-18-2023, 06:43 PM
RE: Genode OS - by nfeske - 10-19-2023, 02:29 AM
RE: Genode OS - by Kevin Kofler - 10-18-2023, 05:51 PM
RE: Genode OS - by PineFone - 10-19-2023, 03:39 PM
RE: Genode OS - by Kevin Kofler - 10-19-2023, 08:30 PM
RE: Genode OS - by PineFone - 10-23-2023, 03:47 PM
RE: Genode OS - by Kevin Kofler - 10-23-2023, 04:56 PM
RE: Genode OS - by PineFone - 10-23-2023, 05:18 PM
RE: Genode OS - by nfeske - 10-26-2023, 06:56 AM
RE: Genode OS - by PineFone - 10-30-2023, 04:34 PM
RE: Genode OS - by PineFone - 11-02-2023, 09:01 PM
RE: Genode OS - by nfeske - 11-10-2023, 09:32 AM
RE: Genode OS - by tllim - 11-11-2023, 09:35 PM
RE: Genode OS - by nfeske - 11-14-2023, 03:41 AM
RE: Genode OS - by tllim - 11-17-2023, 12:14 AM
RE: Genode OS - by Josef Söntgen - 11-23-2023, 05:47 AM
RE: Genode OS - by aLoop100o - 11-23-2023, 06:13 AM
RE: Genode OS - by moodroid - 12-28-2023, 11:29 AM
RE: Genode OS - by nfeske - 02-16-2024, 06:48 AM
RE: Genode OS - by tllim - 02-17-2024, 07:01 PM
  Genode- Sculpt OS for the PinePhone (non Linux) Surehand53 1 4,792 11-04-2023, 07:23 PM
  When should new OS's like Genode & NuttX RTOS get their own PinePhone subforum? PineFone 1 2,346 05-17-2023, 06:38 PM
Last Post: lupyuen
  ATTN MODS: Create 'Genode OS on PinePhone' Sub-Forum under PinePhone Software PineFone 3 4,698 02-11-2023, 06:23 PM
Last Post: zetabeta
  Genode OS Now Live (finally a battery friendly PP OS?) PineFone 0 2,450 02-04-2023, 09:38 AM
Last Post: PineFone
Lightbulb Article: Experiments for super low PinePhone power consumption with Genode Surehand53 1 3,655 12-27-2022, 02:21 PM
Last Post: Samurai_Crow
