PineBook Pro dead
First, the LED not turning on is not necessarily an indication of not powering on. The power LED is turned on by software; and if the software fails, the LED does not light. A better indication of power, without opening up the device, or measuring voltage, is by feeling the bottom cover near the CPU and seeing if it's warm or hot. Disabling the eMMC, unless you have a known good bootable micro-SD card inserted, will not make troubleshooting easier.
If the battery was fully drained (it sound like that might be what's happened to you), you may need to charge by USB-C. I'm not sure why this would be, but it is widely reported.
I recommend putting the bypass cables back for now; for connecting them incorrectly will cause much more trouble.
10 seconds is probably not enough to totally power off the PBP if it is crashed. I think 20 seconds is the normal recommendation.
:wq
[ SRA accepts you ]
Everyone wants me to quit using NetBSD
PineBook Pro dead - by ottahe - 08-22-2021, 01:07 PM
RE: PineBook Pro dead - by tophneal - 08-23-2021, 09:11 AM
RE: PineBook Pro dead - by KC9UDX - 08-23-2021, 04:47 PM
RE: PineBook Pro dead - by ottahe - 11-03-2022, 01:33 PM
RE: PineBook Pro dead - by pineymousepad - 11-13-2022, 06:12 PM
RE: PineBook Pro dead - by wdt - 11-03-2022, 02:28 PM
RE: PineBook Pro dead - by ottahe - 01-15-2023, 12:29 PM
RE: PineBook Pro dead - by KC9UDX - 01-16-2023, 07:51 AM
RE: PineBook Pro dead - by wdt - 01-17-2023, 05:24 AM
RE: PineBook Pro dead - by ottahe - 01-18-2023, 07:41 PM
  Yet another new Pinebook keyboard problem MikoBob 3 173 09-11-2024, 07:05 AM
Last Post: MikoBob
  HDMI or VGA From Pinebook Pro via Pinebook Pro Docking Deck? segaloco 4 2,381 05-06-2024, 09:27 AM
  Pinebook Pro on Debian 12 Power Issue u974615 1 725 03-13-2024, 10:46 AM
Last Post: u974615
  Pinebook Pro Source for Trackpad Flex / Ribbon Cable rankharris 1 677 02-17-2024, 07:06 PM
  Pinebook Pro charging issues tomekdev 1 1,005 01-05-2024, 08:40 PM
Last Post: tomekdev
  Replacement battery for PineBook Pro DrYak 3 1,798 11-07-2023, 10:09 AM
Last Post: DrYak
  Pinebook Pro Revised Keyboard Firmware jackhumbert 73 144,238 09-13-2023, 03:43 AM
Last Post: k3dAR
  Pinebook Pro malfunctioned hardware samtux 10 5,705 12-27-2022, 03:31 PM
Last Post: samtux
  PineBook Pro revision 2.2: Wishlist for the hardware issue fixes dsimic 115 155,366 11-30-2022, 04:28 PM
  Decent Pinebook Pro barrel PSU / Charger petaramesh 3 2,374 10-21-2022, 07:57 AM
Last Post: dachalife
