Both hinges completely failed
I have read a number of reports of this. Is it only a problem on the older PBPs?
I am thinking about buying one on the next production run, maybe I will add some epoxy or other strengthening to the affected corner(s) to try and stave off this problem (if it even still exists).
Cheers,
TRS-80
Protocols, not Platforms
Both hinges completely failed - by phuzy - 08-10-2021, 05:52 PM
RE: Both hinges completely failed - by barray - 08-10-2021, 11:05 PM
RE: Both hinges completely failed - by KC9UDX - 08-11-2021, 12:14 AM
RE: Both hinges completely failed - by wpeckham - 08-11-2021, 01:56 PM
RE: Both hinges completely failed - by KC9UDX - 08-11-2021, 09:15 PM
RE: Both hinges completely failed - by phuzy - 08-11-2021, 03:29 PM
RE: Both hinges completely failed - by karlyn - 08-23-2021, 08:52 PM
RE: Both hinges completely failed - by josmo - 08-15-2021, 08:18 AM
RE: Both hinges completely failed - by binholz - 10-18-2021, 07:14 PM
RE: Both hinges completely failed - by TRS-80 - 10-29-2021, 08:39 AM
RE: Both hinges completely failed - by calinb - 08-13-2023, 10:22 AM
RE: Both hinges completely failed - by dachalife - 08-14-2023, 10:42 AM
RE: Both hinges completely failed - by KC9UDX - 08-15-2023, 04:38 PM
RE: Both hinges completely failed - by dachalife - 08-16-2023, 01:22 PM
RE: Both hinges completely failed - by KC9UDX - 08-16-2023, 04:19 PM
RE: Both hinges completely failed - by dachalife - 08-17-2023, 07:29 PM
RE: Both hinges completely failed - by KC9UDX - 01-01-2024, 12:02 AM
RE: Both hinges completely failed - by dachalife - 01-01-2024, 04:16 AM
RE: Both hinges completely failed - by Uturn - 01-02-2024, 02:03 AM
  eMMC failed Dendrocalamus64 17 21,534 06-21-2025, 04:34 PM
  Is there a way to turn off Wifi completely? jirow 10 16,560 06-20-2022, 05:53 AM
Last Post: Kaythe
  Stiff hinges or a lid that no longer shuts dsimic 3 6,610 10-05-2021, 12:10 PM
Last Post: ab1jx
  Write to an A1-rated Micro SD card failed dsimic 12 20,336 07-28-2021, 11:38 AM
Last Post: dsimic
  Plastic Spacers at Hinges - Substitution hmuller 1 5,144 11-15-2019, 12:01 PM
Last Post: hdk
