Mobian repository status
(08-10-2021, 02:25 AM)jed Wrote: @biketool Your SourcesList may be malformed, see the Debian Wiki: sources.list format, Example sources.list
Try this:
deb http://deb.debian.org/debian/ unstable main contrib non-free
The SourcesList is composed such that you define:
  • The type of archive, binary or source code (deb, src)
  • The mirror, in this case the geo mirror (http(s)://deb.debian.org/debian/)
  • The distribution or codename (unstable, sid)
  • The component(s) (main, contrib, non-free)
There is an FAQ entry for this, I'd suggest not interfering with the repositories beyond what is outlined there, as Mobian takes an unorthodox approach to configuring repositories.
Yup...  it was the space between deb.debian.org/debian and sid(or buster)  I commented out my line and added
deb http://deb.debian.org/debian sid contrib non-free
we are all good now, thanks for the reference!
Just to not I had to hand add the sources.list file it was missing in this install.
(edit)
I also tweaked /etc/apt/preferences.d/00-mobian-priority so mobile friendly Mobian updates are chosen over Debian
I moved /etc/apt/preferences.d/00-mobian-priority to /etc/apt/preferences.d/00-mobian-priorityOLD
then made a new /etc/apt/preferences.d/00-mobian-priority
Package: *
Pin: release o=Mobian
Pin-Priority: 700
Package: *
Pin: release n=sid
Pin-Priority: 300
Package: *
Pin: release o=Debian
Pin-Priority: 500
Mobian repository status - by henrythemouse - 07-24-2021, 11:00 AM
RE: Mobian repository status - by Zebulon Walton - 07-24-2021, 06:22 PM
RE: Mobian repository status - by biketool - 07-26-2021, 09:32 AM
RE: Mobian repository status - by henrythemouse - 07-28-2021, 09:34 PM
RE: Mobian repository status - by biketool - 08-01-2021, 05:43 AM
RE: Mobian repository status - by biketool - 08-03-2021, 04:23 AM
RE: Mobian repository status - by biketool - 08-09-2021, 09:38 AM
RE: Mobian repository status - by User 18618 - 08-10-2021, 02:25 AM
RE: Mobian repository status - by biketool - 08-10-2021, 04:15 AM
RE: Mobian repository status - by nelstomlinson - 08-10-2021, 09:56 AM
RE: Mobian repository status - by User 18618 - 08-15-2021, 02:42 AM
RE: Mobian repository status - by bcnaz - 08-15-2021, 06:17 AM
RE: Mobian repository status - by nelstomlinson - 08-15-2021, 09:17 AM
RE: Mobian repository status - by covar - 04-09-2024, 09:44 AM
RE: Mobian repository status - by ragele - 04-09-2024, 02:11 PM
RE: Mobian repository status - by walter1950 - 04-10-2024, 06:21 AM
RE: Mobian repository status - by diederik - 04-10-2024, 10:02 AM
  atinout binaries for mobian/debian? NeutralGrey 2 117 05-13-2024, 02:42 PM
Last Post: Gumur
  bookworm vs trixie discussion for mobian in pinephone regular. zetabeta 26 2,820 05-09-2024, 03:08 AM
Last Post: anonymous
  cant verify mobian image at website gnugpg penguins_rule 0 171 03-18-2024, 08:54 PM
Last Post: penguins_rule
  mobian installed to eMMC - how to install tow-boot grump_fiddle_reinstall 6 2,132 11-22-2023, 11:46 AM
Last Post: aLoop100o
  What actions needed to keep on mobian testing user641 3 1,905 09-05-2023, 06:44 AM
  Mobian boot failed with zstd message after upgrade. Mahgue 0 666 09-01-2023, 11:29 AM
Last Post: Mahgue
  Problem with updates: Repository 'Debian bookworm' changed its 'non-free component' Anna 7 2,764 08-31-2023, 12:38 PM
Last Post: vusra
  how to update mobian over tor vusra 13 7,183 07-09-2023, 08:57 PM
Last Post: vusra
  opensnitch outbound firewall now works on mobian vusra 2 1,967 07-09-2023, 01:37 AM
Last Post: vusra
  Using Nativefier on PP64 with Mobian paulcarton 0 662 07-05-2023, 03:57 AM
Last Post: paulcarton
