07-20-2021, 02:41 PM
there are dozens of checks that can be performed, first you check the hardware connections, then you run mmcli if you are using ModemManager (phosh) or ofonoctl if you are using ofono (plasma), then you can check the DBus and last the AT commands, have a look at my guide for the Quectel Mobile Data Configuration
