Programs unable to open display via sudo or pkexec (linssid not working)
Linssid would be a useful tool for wireless network survey (at least 2.4 GHz) but although it installs it aborts on an error when run, apparently a problem with connecting to the display. This then precipitates additional errors, however the inability to connect to the display seems to be the actual issue. (Linssid uses pkexec to run with root privileges.) This appears to be a generic problem running any program as root via pkexec or sudo , for example a similar error occurs running "pkexec nemo" or "sudo nemo". I'm really not very familiar with Wayland, is there a way around this?
Invalid MIT-MAGIC-COOKIE-1 keyqt.qpa.xcb: could not connect to display :0
qt.qpa.plugin: Could not load the Qt platform plugin "xcb" in "" even though it was found.
This application failed to start because no Qt platform plugin could be initialized. Reinstalling the application may fix this problem.
Available platform plugins are: eglfs, linuxfb, minimal, minimalegl, offscreen, vnc, wayland-egl, wayland, wayland-xcomposite-egl, wayland-xcomposite-glx, xcb.
Aborted
Programs unable to open display via sudo or pkexec (linssid not working) - by Zebulon Walton - 07-20-2021, 09:50 AM
  New camera app gnome-snapshot working on trixie? vusra 4 2,898 04-11-2025, 02:53 AM
Last Post: vusra
  Calls 4G not working oliwierzgorniak 2 3,937 08-06-2024, 02:20 PM
Last Post: baptx
  Unable to wake up from suspend xavi92 6 5,425 07-28-2024, 02:48 PM
Last Post: dchang0
  Mobile internet via cellular network mostly not working Anna 18 20,746 01-19-2024, 02:59 AM
Last Post: anonymous
Exclamation The internal speaker stops working anonymous 6 5,567 01-17-2024, 05:53 PM
  Unable to do initial setup of Weather due to keyboard LibrePhoneUser 2 3,117 07-07-2023, 03:29 AM
Last Post: jojuma
  APN settings not working with new operator SIM card user641 1 2,662 03-01-2023, 04:43 PM
  Mobian + phosh firefox ublock and other overlays display bugs tuxcall 3 3,960 02-24-2023, 12:11 AM
Last Post: nexion
  Possible Solution for Microphone Not Working Ferriah 0 2,092 02-13-2023, 01:09 PM
Last Post: Ferriah
  Mobian external display woes Hiraghm 5 5,657 12-09-2022, 12:12 PM
Last Post: gregb49
